Question about Cell Phones
Pin code for offices whores 2 behind closed doors. 20403
Dvd
2 Suggested Answers
ssimons47
  • 6258 Answers
SOURCE: whats pin code to club co/ed whores
good one
Posted on Oct 15, 2017
I have Konica Minolta B250it does not warmup.the fused unit is cold and the touch screen is not responding just freezing. I have tried trouble re-set changed fuser unit. Changed control panel nothing is...
Fuser Error is not getting reset.
Try to look into the Right Door SWITCH which is located behind the Front Toner Door.
U need to remove front cover and u will find switch back of steel cover.
check the actuation once u close right side door, it might not be on or off by opening and closing right door..
Jul 21, 2017 | Konica Minolta Office Equipment & Supplies
DVD door will not open to eject DVD
There could be 2 reasons, 1. Hardware issue 2. Software drivers:
Fixing 1: Hardware
Make sure the DVD is fixed properly in your tower ( I am not sure whether you are using a tower or lappi)
The direct solution is to put a pin i the small hole present on your DVD player. That should open the DVD door.
To fix the software part.
>> Try to update the drivers depending on the operating system you are using.
>> Download the latest drivers to check if it fix the issue.
>> Open the My computer >> Right click on the CD/DVD drive and select Eject, this will normally open the door.
Else, try to uninstall the drivers from Device Manager and then restart the PC once, this will reinstall the drivers once again by its own if your Windows is up to date.
Please do get back to us, if that does'nt fix.
Jan 18, 2014 | Zenith XBV243 DVD Player/VCR
What does error code E41 mean
Communication error with the circuit and control board. Professional technician will need to :
1. Is the loading door closed? No, close the door. Yes, go to step (2). 2. Disconnect the plug from J2 on the Main Control Board and check for continuity between the pins in the plug. Open, check the door strike. If good, replace the door switch assembly. Closed, replace the Main Control Board.
Aug 04, 2012 | Frigidaire Washing Machines
Code e41
You have a communication error. 1. Is the loading door closed?No, close the door. Yes, go to step(2).2. Disconnect the plug from J2 on the Main Control Board and check forcontinuity between the pins in the plug. Open, check the door strike. If good,replace the door switch assembly. Closed, replace the Main Control Board.
Jul 17, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have many ring binders and I don't know if they should be presented on my bookcase or hide them behind closed doors
It depends where you put them - if you plan to put it in your home office, that make sense and I don't think that you need to hide them. Remember that there are some very cool colorful looking binders and you can use them to add a little color and character to your home office. If you are planning on the living room - it is a different story and then maybe you should consider bookcases with doors.
May 30, 2012 | Furniture
My door ajar light stays on which causes my dome light to stay on also on my 2003 ford ranger fx4 level 2.
Hi
there are small pin switches in the door, when the door pushes up againsit it in the closed position the pin switch goes in and turns the light off, if defective then they can stick internally causing this fayult, also there are 2 wires behind them that can corrode and start to decay, normally only one or 2 screws to remove the switches spray with wd40 any other faults would be obvious once you have removed it. there is one on each door including the boot although the boot / trunk will normally be seperate.
Hope this helps
Regards
Dan
p.s do you need any pictures ??
Jan 01, 2011 | Ford Ranger Cars & Trucks
How to remove door for whirlpool oven RBS305PDB2
open the door about 1/3 of the way and lift it off the hinge pins. it helps to have two people do this. when it is time to replace it, put the hinges in that 1/3 open position and slide the door back down on.
Oct 02, 2009 | Whirlpool RBS305PD Electric Single Oven
DVD Drive door stays open
>One solution is to TAKE A SMALL PIN AND RESET YOUR DRIVE BY POKING THE PIN INTO THE HOLE BELOW THE DOOR..
If this doesnt solve....
You need to necessarily replace the drive..
Jul 07, 2009 | Samsung SC 152 Internal 52x CD-ROM Drive
Cell Phones Logo
118 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
