Question about Craig Electronics CHT909n Tower Speaker System with FM Radio
Craig tower speaker no sound
Everything is lighting up but no sound
Manual for icraig tower speaker
go to manuals.com. see if it is there.or go to craig.com. lol.
Jul 06, 2014 | Alpinestars Craig Snapback Hat Red
Craig speakers
I had the same problem and I hope this awnser will help because there could be multiple problems, but my solution from experience is that the charger on top of the speaker has been moved forward and even being just a centimeter can mess it up so what I do is when I put my device on it I wedge the system remote begin the device and I'm te hole of the charger pocket where the phone goes, to push the phone forward so it can connect to the speaker
May 12, 2014 | Craig Tower Speaker System For iPod,...
Power will not come on. Indicator light is off as well.
Sounds like you have a fuse problem. Check the fuse and if that;s not it then more than likely you have Problems in the power supply. It should have a year warranty on it. I would take it back.
Mar 12, 2014 | Craig Electronics CHT909c Tower Speaker...
ICraig Tower Stereo system will not turn on from standby
sometimes the system can get a little "rusty" after inactivity. The most common simple solution is to unplug it then plug it back in
Jan 01, 2014 | Craig Tower Speaker System For iPod,...
How do u turn on the ubs on the craig speaker
sorry. I can't say because I don't know if you are fixing your car or stealing one. Best bet is to call the dealership or hit up google.
please rate these
Jan 20, 2013 | Craig Tower Speaker System For iPod,...
how do you set the sd card back to the begaining without the remote?
Dec 29, 2012 | Craig Electronics CHT909c Tower Speaker...
How to double check speaker hook up on asus desktop computer
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties.
May 02, 2012 | ASUS Computers & Internet
Craig Electronics CHT909n Tower Speaker System with FM Radio Logo
59 people viewed this question
Top Craig Audio Players & Recorders Experts
odiegh
odiegh
 Grubhead
Grubhead
Gyula Lacz
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
