Question about Ice Super Chexx Non-Coin Deluxe Home Bubble Hockey Table
My super chexx bubble hockey wont power up its plugged in but no lights music nothing
    New Friend:
    Problem Solver:
  • 6 Answers
Did you check the outlet
Posted on Feb 21, 2014
Does the Air Hockey table require lots of electricity?
An air hockey table requires a lot of electricity in comparison to other electrical devices in your house due to the air inflating machine. Try turning off the Air Hockey table every time you're done playing with it to cut on the electrical bill, I've done this mistake of keeping the table running for nothing on the first month and I've learned my lesson.
Jul 25, 2012 | Sport & Outdoor - Others
I have a F350 7.3 deisel that wont start. Starter wont do anything. has new batteries. lights and everthing else works
is the truck standard or auto
is there a click or as stated nothing
are the wires at starter clean and tight
is there power going to starter selenoid (signal wire)
if auto try starting in nutral
if standard try to by pass clutch switch
is power going across starter selenoid
is the ignition fuse all o.k.
May 20, 2011 | 2000 Ford F350 Super Duty Super Cab
Rock-ola cd jukebox bubbles wont bubble?????
They are probably made like the old Christmas tree bubble lights. These had a solution, I think it might have been calcium chloride and they were heated at the bottom end of the tube by an incandescent lamp that ran pretty hot. The lamps in your unit might be burnt out. I remember we had to tap the tubes lightly to get them to start bubbling sometimes.
Feb 16, 2011 | Wurlitzer Rock-ola Jukebox
I turn my Super Nes console on and nothing happens. The light doesn't come on, seems to be not getting any power to it. Could it be the cord?
Check the cord for output power, you can use a voltmeter for this, of it your gusty use your tongue, it wont hurt you much it's pretty close to 9 volts if I remember right. If that has power check to see if the part you plug the cord into is loose at all, it may of been broken off on the inside and needs to be re-soldered. if both of those fail you might want to check any of the connections on the main board for bad solder points. I do think it might just be a worn power supply/cord
Nov 06, 2010 | Nintendo Super NES Console
Tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Apr 15, 2010 | LG 32LG30 32 in. LCD HDTV
I think the electronics in my Super Stick Hockey table need replacing. The table is approx 18 years old and has been in and out of storage. Battery compartment shows some buildup, and scoreboard doesn't...
Those are all signs of bad voltage pickup get yourself a new battery box from the shack and be done with it. That should do the trick and next time if you store anything with a battery including your car take out the batteries or unhook the cable. Have a nice day
Nov 18, 2009 | Carrom Super Stick Table Hockey Game
Sportcraft Turbo Hockey table will not power up
The customer service is somewhat oblivious to their inventory and products they sell. But, if your table is not pushing the puck, call and order a new fan (easy swap out). Also, you may use a small pin and poke each air-hole as dust accumulates and clogs system (do not use a wax or polish, only damp soft cloth)
The control box is the interface to power scoreboard.(kids pushed the transformer cord in too hard and separated the circuitry panel inside CB). I am in process of replacing mine, model number 34090, part number 34090HG08, $5.00+ SH
There are comparable control box modules for similar turbo hockey games, Atomizer, which uses a similar control box that you can swap circuitry out to your old box. (Very simple, even a cave man can do it..hah). The key is the ability to put control box back together once you disassemble inerts. (The "flip" mechanism is so shoddy it never goes back together right)
Good luck with Sportcraft and their disposable $500-600.00 air hockey tables which have a lifespan of parts of less than 5 yrs!
Nov 17, 2008 | Fat Cat 7' Air Hockey Table
Ice Super Chexx Non-Coin Deluxe Home Bubble Hockey Table Logo
Top Ice Sport & Outdoor - Others Experts
Bill Eager
Are you an Ice Sport and Outdoor - Other Expert? Answer questions, earn points and help others
