Question about Kenmore Dishwashers
Kenmore dishwasher 665.1348 ultra wash - Kenmore Dishwashers
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
  • 4 Answers
SOURCE: Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Posted on Jul 01, 2008
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Posted on Apr 21, 2009
  • 83 Answers
SOURCE: Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Posted on Jul 02, 2009
SOURCE: dishwasher will not drain ...kenmore
Failing to drain is either a blocked drain line or a broken drain pump. First check inside for blockages. When you first turn it on, you should hear a click and a whirring, that's the drain pump turning on. If you don't hear this, your pump is not working. To replace the pump you will have to order the right part, remove the front panel and install it. It usually goes in from the front, bottom, but it's much easier if you remove the DW and tilt it on it's back. It's a fairly simple install, 2 hoses, 2 wires, a few screws and it drops right in.
If you do hear the pump working, then you likely have a clog and you'll want to trace along the drain line to isolate and remove it manually.
Posted on Nov 20, 2010
Kenmore ultra wash dishwasher
Bad triac on control board. Replace control board.
Aug 23, 2014 | Kenmore 24" Built-In Dishwasher with Ultra...
Kenmore Ultra Wash dishwasher displayed locked and will not start?
Look under the machine for a bag, with the
diagnostic manual, they don't want you to
know about,so you can wait two weeks for someone
you pay, to arrive,by then you will have it repaired yourself
Aug 16, 2014 | Kenmore PRO 24 in BuiltIn Dishwasher with...
How do you open the soap dispenser on a Kenmore Ultra Wash dishwasher?
Push the little lever sticking out of the dispenser.
Maybe you have some calcium or hardened soap that is holding the lid closed. some Lemi-Shine powder dissolved in hot water and use an old toothbrush to clean off the soap/hard-water deposits.
Jul 27, 2014 | Kenmore 24" Built-In Dishwasher with Ultra...
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Dishwasher Problem
According to my ultra wash dishwasher you have to hold the no heat dry button for 4 seconds and that is how you lock and unlock the control panel
Jun 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Nov 02, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
98 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
