Question about Optimus Heating & Cooling
Heater does not switch on
The heater is plugged in, but when you switch it on, it does not come on. the lights in the switches do not come on either.
  • Clay Moretton
    Clay Moretton Nov 27, 2013
    of course I checked the power outlet. It was plugged into a power strip with other things. I even tried changing the plug in location on the strip.
  • David j Dono Nov 27, 2013
    now you have verify if power is making it past on/off switch if not switch is bad. if it is getting past on/off sw. then continue to follow till find at what point it is stopped.
  • 69 Answers
Did you check for power where plugging it in???
Posted on Nov 27, 2013
Why won't the burners light if my pilot is lit
check safety circuit pressure switch should have 24 volts on both wires if not bad switch or copper tube plugged or loose wires to gas valve
May 11, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Pressure switch light blinking?
make sure filters are clean then make sure wires are tight on pressure switch then make sure voltage on both sides of pressure switch if not check copper tube to see if plugged
Aug 07, 2013 | Jandy Laars Lt 400,000 Btu Heater
Jandy lt250 heater has air flow message
make sure 24 volts ac on both sides of pressure switch if not replace pressure switch or copper tube is plugged if only 10 or so volts will not keep gas valve open
Nov 21, 2012 | Jandy Laars Lt 400,000 Btu Heater
Pressure switch fault on jandy xl POOL HEATER
check to see if pressure switch has voltage both sides also check copper tube to see if plugged
Nov 12, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a 1991 buick rivera it has no heat from the heater. I have had the cooling system flushed. I changed the temp control module.But nothing Changed.wife getting cold in tennessee winter need help.does...
Sounds like a bad heater element switch or heater core. Sound like the heater control switch. On the front side of the heater core you should find a plug. Pull the plug and remove the two screw. The switch should come out. Replace it.
Jan 10, 2011 | Buick Riviera Cars & Trucks
The dsi flt light will not stay off. water heater is being used by electricity only and gas is off. what do we do and whar is cause of this.
The dsi light is powered by 12 volts, either from trailer converter, or a plug in to a receptacle that converts it to 12 VDC. It sounds like a faulty switch, if you switch it to off and it doesn't go off. . Temporarily, you can pull switch out and disconnect 12 VDC power at spade connector on switch. Be sure to wrap electrical tape around bare spade (female) that has incoming 12 VDC, until you replace switch. Is the water heater actually trying to ignite on gas when light is on? If you don't want to pull switch, look for fuse in fuse panel for water heater, or under counter or wherever, near water heater area for an adapter plugged in with wires running to the water heater and simply unplug the adapter at the receptacle.
Jan 09, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
The power button does not turn on the heater. It is plugged in to a owrking outlet. Is there a switch problem?
Does your heater have apush button switch or toggle type. Either way if you push in button type and it won't stay in then switch is bad. Will heater come on if you push switch on and hold it? There should be a small red light on top and fan inside of heater. Do they work? If it was me and I really thought that switch was bad I would remove back and wire around switch. If you don't feel comftortable doing this then you are probable better off just getting a new heater. If you do decide to try wiring around switch make sure heater is unplugged and try to trace wires to switch. If it's just a simple on off switch there should be two wires going to it. Disconnect them from switch and temporarily connect together.Plug heater back in and if it works you know switch is bad. Remember if you don't feel comfortable doing this then don't do it. Most of these small electric heaters are available for around twenty dollars,so I wouldn't spend much time or money trying to fix this one.Hope this help some. Thanks
Nov 10, 2010 | Pelonis Heating & Cooling
Looking to put remote start and bypass module in 2007 saturn vue need wiring diagram
12 VOLT CONSTANT ORANGE (+) IGNITION SWITCH HARNESS STARTER YELLOW(+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK(+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE LIGHT GREEN (-) See NOTE *1 IGNITION SWITCH HARNESS PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) BROWN (+) @ BCM, PIN B10, GRAY 24-PIN PLUG, See NOTE *2 POWER LOCK RED/BLACK (TYPE A) @ BCM, PIN A8, 16-PIN GRAY PLUG, See NOTE *2 POWER UNLOCK ORANGE/BLACK (TYPE A) @ BCM, PIN A7, 16-PIN GRAY PLUG, See NOTE *2 LOCK MOTOR WIRE GRAY (+) IN DRIVERS DOOR HARNESS DOOR TRIGGER See NOTE *3 @ BCM, PINK 24-PIN PLUG, See NOTE *2 8957_VUE_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf DOMELIGHT SUPERVISION WHITE (-) @ BCM, PINK 24-PIN PLUG, PIN A1, See NOTE *2 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK (-) @ BCM, PIN B2, PINK 24-PIN PLUG, See NOTE *2 TACH ANY WIRE NOT PINK or RED @ IGNITION COIL WAIT TO START LIGHT N/A BRAKE LIGHT BLUE (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM DISARMS with FACTORY REMOTE ONLY ANTI-THEFT YELLOW (+), ORANGE/BLACK (-) and RED/WHITE (Not used) GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column.
Feb 27, 2010 | 2007 Saturn VUE FWD 4
Our pilot light on our Teledyne Laars ESG250N will light but our heater wont come on. Can anyone help me find any info on our old heater?
check pressure switch should be 24 volts on both terminals if not bad switch or plugged copper tube you can jump just to check
Jun 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
145 people viewed this question
Top Optimus Heating & Cooling Experts
Mack Baxter
L Pfaff
L Pfaff
Are you an Optimus Heating and Cooling Expert? Answer questions, earn points and help others
