Question about Minolta Maxxum 3000i 35mm SLR Camera
Battery damage The LSD screen is completely blank, and sections of the plastic covering the battery case is cracking. Does damage to the exterior case of the battery cage cause the camera not to work?
  • 7,993 Answers
I would not know. Seems pretty beat up. Try it anyway. Put batteries and pretend that there is a film inside and operate the camera. You can even open the back, and shoot a picture and watch the mechanism operating.
Posted on Nov 27, 2013
Lg reset
Sounds like the LCD digitizer which either broke inside OR became disconnected. If the impact was not enough to sustain a screen crack, and you have warranty with either LG or through your carrier, you can get LG to fix it free if there is no physical damage, cracked screen, or water damage, with your carrier, it would be the easy, just tell them the screen isn't broken, the phone is intact but the screen is blank. That is a hardware failure... they are supposed to be able to withstand some drops so it really depends on how much physical damage there is.
A digitizer LCD is not expensive and there are ways to change them fairly simple since the screen isn't cracked, you go through most LG phones via the back, remove the camera, remove a black cover that holds the sim and or memory card, BE CAREFUL and please look at youtube to see a complete disassembly of your particular LG phone.
Jul 16, 2014 | LG Cell Phones
I droped my labtop and has shaddered aperance and will not boot up
Take out battery, then remove the hard drives and get a new laptop
Dec 08, 2012 | Samsung 300E5A-A03 laptop
Logitech harmony one
  • Dear Sir:
    Turn off the power to your computer and unplug all cables connected to it. Remove the battery, if one is installed.
  • 2
    Locate the covered screws around the cracked screen. Remove the rubber or plastic covers, then unscrew the screws.
  • 3
    Gently remove the plastic frame around the cracked screen and set it aside. Disconnect any power cords or cables going into the LCD screen.
  • 4
    Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
  • 5
    Reconnect all internal cords to the screen. Screw in the frame and replace all the screw covers.
  • 6
    Reconnect the power supply and all external cables to the LCD screen and switch it on.
    sincerely. God bless you
    ernesto cuadra
    managua, nicaragua. c.a.
  • Feb 15, 2012 | Logitech Harmony One LCD Touchscreen...
    My phone charge as normaly but with exsees heat and discharge so fast when i get phone call and i answer. pls help me
    all lithium-ion cells are soft, but most cellphones have a hard plastic cover to protect the cell and keep the connections in place. the battery works by allowing energy to flow from one section to the other to store or discharge energy. these two sections are separated by a fragile membrane than if damaged may allow a higher rate of transfer causing excessive heat within the unit. This was all said to give you an accurate depiction on how the battery may behave when damaged, submerged in water, or if you have are always charging your device.......try not to overload your battery by charging it every chance you get...........also look for any sign of physical damage on the surface of the battery below are all the signs of a physically damaged battery and the best methods of they're detection.......
    1. a swollen battery ..........hold the battery flat looking down its wide side, if it is not completely flat then the cell has been damaged in some way
    2. single or multi axial stress........make sure you can lay and stand the battery on a flat surface and have no gaps between the two.
    3. look for gouges or holes in the battery
    The presence of these physical deformities is not guaranteed with all battery malfunction.....some just happen, but this will help diagnose most cases.
    Good Luck and Please Rate This Post!!!!!!!! :D
    Oct 13, 2009 | Cell Phones
    My Matrix has a cracked screen, and I can not see anything on the screen. Can it be repaired?
    hello
    As far as screen is concerned it cannot be repaired.
    In these cases screen is completely replaced by a new one.
    but you please check if the screen is damaged or its cover because covers are more easily replaced.
    Thank you
    Aug 18, 2009 | Pantech Matrix Cell Phone
    How do Iopen the case of an HPvs17x monitor?
    The Capacitors on the power board are usually the reason for failure of an LCD. If you open the HP VS17 ( I can provide an exhaustive step by step If I have to) remove the five screws for the power board ( larger of the two boards) and look for an area where there are 4 caps (see pic). Look for exploded, popped up, bulging, or leaking caps and replace with the same or slightly higher tolerances. The one I replaced last night were (2x )1000uf25-50volt and (2x) 470uf25-50volt. Check the rest of the board for similar issues and replace as needed.
    Jan 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
    Replace exterior driver door handle
    If you remove the inner door panel of the door there will be plastic weather shield covering most of the door. Use a hair dryer or heat gun to heat the weather shield up and slowly peel it away. There will be 2 (10mm I believe) bolts on the inside of the door panel to release the handle (have someone catch it from the other side). To re-install simply connect he handle rod and 2 bolts then place the door panel back on and your done. A word of advice is be gentle with the door panel so not to damage the door pins or crack the plastic. Taking your time can be fun when learning a car ;).
    Jul 03, 2008 | 2000 Toyota Corolla
    Repairing a razr
    you simply need a replacement screen, or do as I have and redneck mod one. If you get the screen take off the faceplate, (reply with email address for guide), remove the cracked screen, and glue on the new one. (WARNING, NEVER PRY OFF THE CRACKED SCREEN ON TOP OF THE LCD SCREEN) putting pressure on this could completely damage your phone. The other way is to again remove the face plate and cracked screen. then find a hard plastic or plexiglass, cit it out to size and there you go. you can even paint the edges black on the bottom side of the screen and very few will know the difference if you do this correctly.
    May 16, 2007 | Motorola Mobility RAZR V3
    Minolta Maxxum 3000i 35mm SLR Camera Logo
    29 people viewed this question
    Top Minolta Photography Experts
    Greg Cann
    Greg Cann
    TC CAMERA REPAIR.Com...
    Are you a Minolta Photography Expert? Answer questions, earn points and help others
