Question about Grizzly Big Bear Atv Maintenance Free Battery
ATV stalls out when I apply hand or foot brake what is my problem>?
Applying the brakes kills the engine hand brake or foot brake?
    Habit-Forming:
  • 88 Answers
Check servo connections and hose for seal and wear
Posted on Nov 26, 2013
'96 Mystique 2.0 trouble with idle. replaced idle mixing valve. I don't get any codes, I have to shift to neutral at a stop sign or light to keep from stalling. It gets real rough almost a lope.
troubles at lights may very well mean a vacuum leak from a faulty brake booster
test by stopping and then applying the park brake and taking your foot of the brake pedal
you can do this test in the garage
start the engine , apply the park brake , place in drive
if it idles alright , put you foot on the brake
if it plays up , replace the brake booster
Jan 24, 2017 | Cars & Trucks
2010 subaru forester engine cuts out
consider this
when at the stop lights , you will have your foot on the brake as it will still be in drive or in gear and you don't want the car to move
a simple test is to apply the hand brake to stop the car and don't touch the foot brake
if it idles ok but cuts out when you apply the foot brake , replace the brake booster as it has a vacuum leak that is causing the problem
you can do this test in the garage by starting in neutral and allowing the engine to idle , then apply the foot brake
iof it dies it is the booster
Oct 01, 2016 | 2010 Subaru Forester
What would cause engine yo die at a stop light and not start again. The engine almost turns over but doesnt.
engines stopping at lights can sometimes be attributed to a vacuum leak in the brake booster
test by idling the engine with the hand brake on and no foot brake then apply the foot brake and if the engine dies then it is the brake booster
hard to restart may be the vacuum leak if you still have your foot on the brake.
May 12, 2015 | Cars & Trucks
Stalling troubleshooting
run fault codes to check for electronic problems (TCM). If this problem only happens when the foot brakes are applied check for brake booster vacuum problem. Remove vacuum line and blank off and apply the brakes to see if the engine stalls at idle.
Jul 22, 2014 | Ford F-150 Cars & Trucks
Engine dies when I apply hand or foot brake?
Hello to all I have a problem on my aston martin vantage v8 when I drive i see message says engine system service required And lose the power Can anyone help me
Nov 26, 2013 | Grizzly Big Bear Atv Maintenance Free...
Yamaha atv troubleshooting
you need to pull in the clutch ??? or your idle is set to high causing the semi-auto clutch to engage causing it to stall... Next time include the year and model for a better/more in depth answer
Nov 26, 2013 | Motorcycles
Car dies when applying the brake
Have your Brake Booster checked for vacuum leaking to the intake manifold. It is that large round object against the firewall in front of the drivers side. When you apply brakes, vacuum is leaking somewhere out of it and will stall or kill the engine
Sep 06, 2013 | 1997 Chevrolet Malibu
Engine cuts out when foot brake applied
sounds to me like a severe vacuum issue...pump the brake pedal quickly while in park if engine start to stall or does stall then take carb cleaner and spray vacuum lines and around intake near gasket engine will rev or die out when you hit a leak...very careful inspection of lines if no money for carb cleaner..or it could be brake booster is bad...loud air sound when pushin or holding pedal would indicate and issue there
Nov 27, 2012 | 1994 Honda Accord
When weather is hot outside after car runs awhile it stops pulling,idle's fine,continues to run but won't pull when clutch is engaged ?
check hand brake tension , sounds like it is grabbing after heating up, or is the clutch on its way out simple test for clutch , hop in car apply hand brake and foot brake place car in reverse let clutch out slowly ,if car stalls clutch is good if car stays running clutch failure, replace clutch
warning read and do it properly hand brake and foot brake on at all times during test,make sure car is in a well open area, hope this helps
Jun 12, 2010 | 1992 Toyota Celica
Grizzly Big Bear Atv Maintenance Free Battery Logo
127 people viewed this question
Top Yamaha Vehicle Parts & Accessories Experts
Coss
Andrew Taylor
Andrew Taylor
ray012965
Are you a Yamaha Vehicle Part and Accessory Expert? Answer questions, earn points and help others
