Question about Fujitsu Fi6130z Sheetfed Scanner
Fi-6130z fujitsu scanner jamming repeatedly
Scanner has been jamming repeatedly the last couple of days and tried to look for anything that it could be getting caught on and found nothing... I've been scanning the same way for more than a year and it has never been this bad... nothing stuck in the paper either...
    Novelist:
  • 104 Answers
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Posted on Dec 27, 2013
5 Suggested Answers
  • 8 Answers
SOURCE: Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
Posted on Jul 15, 2008
Roshan89
  • 271 Answers
SOURCE: Scanner Display Shows False Jam
You can try 1. reseting the scanner 2. uninstalling and reinstalling the software
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Posted on Aug 15, 2008
  • 4 Answers
SOURCE: Fujitsu fi-5900C jams
there are many optical sensors in the paper path, you need to clean all. if not solved, reply with error code with detail code
Posted on Jul 03, 2009
TechSatya
  • 104 Answers
SOURCE: Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Posted on Jul 27, 2010
Testimonial: "Hello TechSatya, The information you have provided is very helpful. We can now notice staple-pins stuck inside the Sensor panel. Thanks a lot."
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
www.fujitsu.com/downloads/.../scanners/.../fi-5650c_ops-guide.pd...
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error Messagesmy.okidata.com/man-OF5650.../006B738F6240C3BF8525678500678C...Make sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Zealandwww.oki.co.nz/support/printer/.../index.aspxOki Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
What's the price of Fujitsu scanner model 5130?
As far as I can tell, a Fujitsu 5130 is a desktop computer, not a scanner. It sells for $2820 new.
A Fujitsu 6130 is a scanner, and sells for about $400 used.
May 16, 2015 | Fujitsu Office Equipment & Supplies
Copy goes through scanner but comes out blank on screen. I know it's being inserted correctly (not backwards).
I'm a 99% sure that you've got some hardware problem with your scanner, probably some internal sensor it has is failing. Just as a test, you should install this scanner on another computer - ask a friend for help - test it and if failure persists you have two options: Live with the failure until it goes worst and stops scanning at all or you take it now to repair.
On the other hand, if it works ok on another computer, try to uninstall it completely and reinstall it.
Dec 22, 2014 | Fujitsu fi-6130z - Document scanner -...
Fi-6130z continueously scans. It doesn recognize when there is no paper to be scanned
Your scanner went crazy. If you don't want to take it to repair, just disconnet it after you've finised scanning
Oct 09, 2014 | Fujitsu fi-6130z - Document scanner -...
Fujitsu Fi-6130Z is pausing after each page scans. How can we stop this so it is a continuous scan!
The command to scan comes from the host computer when it has recieved the previos scan and is done processing the data such as descew and borders. Faster host computer and or faster network if you are saving to a server. If the first few scans are fast then slows down then this is it. More ram in host will sometimes help.
Feb 12, 2014 | Fujitsu Fi6130z Sheetfed Scanner
Hi I'm getting a lower case "c" error code on my fi-6130z. Anyone know what might it be?
Hello Steve,
The flashing "c" on your fi-6130z scanner panel indicates that the ADF was opened when the status was ready("1"). To return to ready("1") status, close the ADF. If the display doesnot return to ready ("1") after closing the ADF, turn the power off then back on. If the problem still persists, you are recommended to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Thanks & regards,
ScanCare
Aug 08, 2013 | Fujitsu fi-6130z - Document scanner -...
Fi-6130z ScandAll Pro won't close
You probably have Roboform as well.
Launch Roboform. It will open in Internet Explorer. Open the settings option.Under the default proflie window select 'applications integration', then uncheck 'automatically attach to Windows applications'. Reboot your system. The program should now close after scans.
Aug 26, 2012 | Fujitsu fi-6130z - Document scanner -...
My Fujitsu fi-6130 scanner randomly makes a clicking noise while scanning. it seems to working just fine but the clicking noise drives me nuts!. It doesn't happen constantly but it happens enough that I am...
If you have a scanner with the manufacturing date of 3/09 - 8/09, then yes, the clicking noise is more noticeable after it heats up. The problem resides in the glass mounting that was made in production in those months. The glass mounting raises up and if scanning thick paper or cards it will jam up. This must be sent back to fujitsu to replace the base assembly, because this is a defect that affected thousands of customers.
Nov 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
Fujitsu fi 5120c e2 error
See page 25 of:
http://193.128.183.41/support/scanner/manuals/fi-5120c_gs_p3pc-1312-01en.pdf
"E2" is "Trouble with the optical system (front)."
That doesn't solve your problem, but at least it narrow downs the focus of your problem.
Dec 05, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Aug 15, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu Fi6130z Sheetfed Scanner Logo
409 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
