Maytag top loader machine .it runs over with water on any cycle.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 77 Answers
The water level sensor is not working. Either the unit has failed completely or the pressure tube that runs from the bottom of the outer tub to the unit (inside the control panel) is plugged with something. Clear that first, then try again.
Posted on Jan 27, 2014
  • 209 Answers
SOURCE: Hoover elite 930 top loader washing machine
I am a recently retired appliance engineer of 20 years start with checking the other solenoid, the conditioner one, it may be that that is not working, and double check the cold one, remove the two wires and check for a circuit, it may be actually filing up initially with hot water without realising it, always work with safety remove the plug before removing panels etc if i have helped rate me please
Posted on Sep 09, 2007
  • 3422 Answers
SOURCE: hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Posted on Jan 30, 2008
docjohn174
  • 943 Answers
SOURCE: maytag washing machine mod # LA882 top loader
HI. thanks for the question. well, not good news for you. the transmission has failed. has broken a gear inside. very costly .suggest buying new. A roper washer. good price. good washer. thanks the appliance doc. please rate my answer thanks.
Posted on Oct 08, 2008
onthejob5130
  • 640 Answers
SOURCE: maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Posted on Jan 03, 2009
I had this problem. I alternated the hot and cold water valves (changing over the wiring) and then hot tap then dribbled instead of the cold. Replacement part i believe is around $35AU
Maytag top loader will not drain all the water out of cloth during the spin cycle
belt tensioner idler pulley out of adjustment or damaged. or belt is worn out. belt is at bottom of machine and if you remove lower front cover, you can run the machine through a cycle and see the problem. my pulley fell off the shaft was on the ground and I had to replace the assembly.
Apr 21, 2014 | Maytag MAV8757AW Top Load Washer
Won't start
if it filled proplerly and won't start now, it sounds like the door switch is broken, there could be something wrong with the rest of the electrical systems, however i would suggest the switch first. If there is a lot of noise like its trying to run, then its probably your transmission.
Jun 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Leaks water on floor and spin cycle very loud
if it sounds like a boeing jet, you will need a new seal & bearing kit. This is something a technician would have to do. many "special" spanner wrenches and spring tools required
Feb 23, 2009 | Maytag PAV2300 Top Load Washer
Maytag leaks water in the spining cycle and makes a loud noice.
how old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
Feb 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Maytag top loader washing machine
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Top Loader won't work on Regular Cycle
I suspect bad motor windings. it has enough power to run delicate but not other cycles?
Nov 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
