Thermistor abnormality during warming up or in ready status.
Turn ON the power while [0] and [8] are pressed
simultaneously.
2. Key in "2002", then press [START].
3. Change the current status counter value "3" or "4" to "0",
then press [OK] (to cancel [C413 / C414]).
4. Turn the power OFF and then back ON. Make sure that the
equipment enters the normal ready state
If the code comes back after conducting this procedure, do not reset again as the machine can catch on fire that will ruin a perfectly good day call a tech
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
this is a fusing code - take it out and see if any build up of toner on the ih cover - remove it if there is. then refit the fuser. Turn machine on holding down the utility key, when comes up with black spot in corner you can relese the utility key. after this a screen will appear after a little while - press the 2 resets (trouble and aes) then switch machine off and on again. use the main switch by tray 1 for this
contact the dealer with your registration there going to want to know your the owner first usualy you take the raidio out and there is a coad on it if thats not the coad the dealer can tell you the unlock coad from the radio coad lol
sir i give u master password but plz give me system disable coad frist u laptop on u five the wrong password 3 time after u get the coad plz send me this coad i give u master coad thanks
its some kind of fault coad showing up,,,hook it up to a computer and find out what this coad is for,,,it sounds like some thing simpel and may just need to be wiped off the cars computer to stop it popping up every time you start the engine
