Question about Acer Iconia B1 7-Inch Tablet Black Dual Core A9 1.2Ghz, 512Mb Ram, 8Gb Emmc, Camera, Wi-Fi, Bt, Android 4.1
THERMAL WARNING Everytime I put on the tablet it says "thermal warning" and shuts down
I rebooted my tablet but why is it still keep freezes?.
ive noticed this happening with my tablet and this can happen if there's too many apps trying to start in the background (resetting may help the tablet power off the tablet and hold the power key and volume up (or down) and select wipe user data/factory reset (warning: anything on the device WILL be lost!) before doing the reset make sure you can recover your files first!!
Apr 21, 2017 | Tablets & eReaders
What is wrong when tablet says thermal critical event occurred and tablet shuts down?
This means the tablet got to hot and presented a fire hazard. Only a few things cause the overheat, first is a failing battery and the last running data heavy programs like complex video games. Those types of programs draw a lot of amps and can overheat the tablet.
Mar 21, 2017 | Tablets & eReaders
Why does this Acer A3_A30 keep "thermal critical shutdown"- every time I do a jigsaw.surely the tablet shouldn't tablet get so hot
what is its ambient temp is it working in daily
temps are way higher inside the casing
if the internal fan has stopped
it will over heat the chips
you can by tablet cooling pads same as laptops
try a cool towel form freezer to rest it on and see if the tablet shuts down
Jun 08, 2016 | Acer Tablets & eReaders
My tablet keeps shutting down. Says thermal shut down. How can I fix this problem? It isn't even 3months old and won't stay on for more than 2 or 3 minutes.
Nextbooks do this when playing intensive games. They just aren't up to the demand on the CPU. Unless you were clearly warned about ths issue I'd say it is a warranty claim. Try to swap it for a games -capable brand.
Nov 19, 2015 | Nextbook Tablets & eReaders
Everytime I use my tablet it shuts down and I have to press the power button repeatedly to get it back on.
The battery must be connected loosely to your tablet due to which there is a disconnection in the power supply to the circuitry and hence it gets shut down.
I feel this could be one of the many of the reasons for shut down.
regards.
Aug 25, 2015 | Samsung 10.1 Galaxy Tab 4 16GB White
Why does it shut down intermittently?
It is over heating. It shuts off to protect the heat from damaging the electronic circuit components.
Aug 02, 2015 | Apple iPad Mini
The screen will not work on my tablet everytime I try to swipe or touch something its like its froze up how do I fix it
Press the Power button longer until your tablet shuts down. If you can restart it, find a cache cleaner software to clear the cache for more space. Sometimes, the cache takes up nearly all the available space from the tablet's ROM. This slows down the tablet considerably and also causes malfunctioning of the OS.
Jan 23, 2015 | Tablets & eReaders
Acer iconi b1 thermal warning
why does my acer iconia keep saying Thermal warning and shutting down when I have only just switched it on?
Nov 26, 2013 | Acer Iconia B1 7-Inch Tablet Black Dual...
Gateway/MPC e295c tablet powers off without warning
I am also having the same issues with my E-295c tablet as well. Were you able to figure out what your problem is? I thought mine may have been my port replicator, but it continues after removing that. And mine always seems to do it for sure everytime I have a full screen video playing. Thanks!
Jul 17, 2009 | Toshiba Portege M200 Tablet PC
Acer Iconia B1 7-Inch Tablet Black Dual Core A9 1.2Ghz, 512Mb Ram, 8Gb Emmc, Camera, Wi-Fi, Bt, Android 4.1 Logo
130 people viewed this question
Top Acer Tablets & eReaders Experts
Nicola Conroy
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
