Question about Toys
Airtronics stylus manual - Toys
Can you reset the pcm yourself
It will reset if you pull the the negative battery cable off for more than a minute and then reconnect it. If you have a clock you will have to reset it after disconnecting the battery.
Dec 14, 2012 | Airtronics Module - Stylus Tx FM-PCM 72Mhz
Airtronics m8 powers turned on its display goes black
My m8 does that too. Have u found a way to fix it?
May 03, 2011 | GPS
When we built our home 6 years ago, Airtron installed a Majestic NVBR36RN vented fireplace system. We had to turn our gas off a while back and never thought about the fireplace until now when we wanted to...
It has a panel hidden under the white fiber hearth bricks at the front bottom of the unit. you need to clean the lava rock off of them, pull both of them up, and then you will see the hidden linear cover that allows you to access the valve and light.
Dec 02, 2010 | Heating & Cooling
I just bought a used mx-3x radio and i need info on how to set up or change setting i didn't get a manual with it, where can i find info on line
Sorry we do not have manual but you can get from info below.
– If you need more information, use these Airtronics resources – E-mail: info@airtronics.net Web Site: http://www.airtronics.net/ Phone: 714-963-0329 Postal Address: Airtronics GLOBAL HOBBY DIST. 18480 BANDILIER CIRCLE FOUNTAIN VALLEY, CA 92708
Good Luck and please rate 4 thumbs for free answer
Mar 02, 2010 | Airtronics Toys
Problem with my Airtron Thermostat
Two things, first go up to the heater and check the fuse inside the heater, looks like a car fuse. If that is not popped, then go outside to your AC unit and pull out the emergency disconnect. Check those fuses with a multimeter. IF you do not get anything replace those fuses, It has nothing at all to do with your thermostat.
Feb 09, 2009 | Honeywell Programmable Thermostat Heater
Left goes to the right
youre holding the remote upside down. Turn it arouns d - problem solved.
Dec 28, 2008 | Airtronics Toys
Toys Logo
79 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
