An LG washer displaying the UE or uE error code means that the load in the washer is unbalanced. ... When the uE error code is displayed, it means that the washer is trying to resolve the issue. The washer will fill with water to try to balance the load. It will then drain and try to spin again.
Jun 7, 2021
You did not post the model number but if this is the top load model, pull it away from the wall and see if the back of the machine that has a galvanized cover, is dented. If the machine walked and thumped because of being off balance, the internal sensors may be contacting the cover.
Q: What should I do if the audio is distorted or drops out on my UE BOOM?
A: Audio distorted or dropping out when streaming to UE BOOM
If you're having trouble with audio distortion or drop-outs on your UE BOOM, try these suggestions:
Move the audio source closer - it might be out of the range of your speaker.
Move away from other sources of wireless signal - you could be experiencing interference.
Make sure your speaker has enough battery power (connect it to a power source with the supplied adapter).
Adjust the volume on both the audio source and your speaker.
Restart both your speaker and the audio source.
Re-pair your device with your speaker (see, "How do I pair additional BluetoothĀ® devices with my speaker?").
If you're using two UE BOOM speakers (for Double Up), try disconnecting and streaming to one speaker only.
NOTE: If you're streaming audio content from the internet, the issue could be with the internet connection and not your speaker.
hold your power and volume up at the same time when it comes on release power button wait 5 sec release volume button you will see sevral ways to restart i had to clear data and ues factory restart just follow promts worked for me
UNBALANCE ERROR - Display shows UE.Laundry load is unbalanced, manually loosen any tangled laundry. If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
