Question about Heavy Duty Arrow T50 Staple Gun
How do i get a staple unstuck? - Heavy Duty Arrow T50 Staple Gun
Where do I find staples for the above Ace 2025 staples?
Most staple guns accept a range of staples of a standard type available from many different suppliers. It is rare that a staple should be manufactured for the exclusive use of a single staple gun.
First you need to know the sort of staple you need. Unfortunately staple gun manufacturers tend to omit this information from their literature and instead use the part number they have allocated rather than the more universal information of type and size.
Fortunately many nail and staple suppliers catalogues contain useful drawings with sizes so identifying any staple, once it has been very carefully measured, fairly simple.
Apr 19, 2016 | Staples Tools & Hardware - Others
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
What Staples does a swingline 34301 Electric Staple Gun take?
That's an easy one
Use the Arrow 600 series staples. heres the link to the different sizes available.
http://www.arrowfastener.com/catalog/supplies/staples/600-series
Good luck and don't forget to rate me :)
Aug 09, 2014 | Staples Swingline® 36115 Staple Guns Tools...
Smith corona typewrite is stuck on special characters
It sounds like your "code" key may be stuck down. See if it is lower than the other keys. Check for a paper clip or staple under the key. Depending on how the keyboard is made you might be able to spray contact cleaner under the key to get it unstuck. I would bend a paper clip with a small bend at the end (90 degree angle) and use it to gently move the key up and then use my finger to press it back down. Do this several times after spraying contact cleaner under the key. Hope this helps.
Jun 04, 2014 | Smith Corona Wordsmith 200 Typewriter
Staple is jammed
Open the area where more staples are inserted, remove the staples, then find the jammed staple. You'll probably have to wrench it out with pliers. Then insert the good staples and try again.
Dec 28, 2013 | Tools & Hardware - Others
Lost the spring that holds the staples in model strapgun 12-14 how can i get new 1
No spring needed
Turn staplegun upside down. At
rear of tool, squeeze latch on
end of staple channel (see Fig-
ure 4). Pull staple channel cover
out of staple channel until it stops
(see Figure 4).
3. Drop staples into staple
channel. Make sure staple
points are facing up (see
Figure 4).
4. Slide staple channel cover
back into staple channel until it
Aug 05, 2010 | Desa International Powerfast Heavy Duty...
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Dec 03, 2008 | Ace Hardware Ace Staple Gun
Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Aug 27, 2008 | Arrow T59 Wire & cable staple gun
Heavy Duty Arrow T50  Staple Gun Logo
41 people viewed this question
Top Heavy Duty Tools & Hardware - Others Experts
yoopertech
Tom Chichester
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
