Question about Toshiba Satellite A105 Notebook
Locks up on boot
I have a Toshiba Satallite A 105 and I turned it on and it will no longer boot. It gets about 2/3 of the way through the bar at the bottom and it locks. If I push f2 to get into the BIOS it says please wait and locks in the same place. I pushed esc to see the details rather then the boot flash screen and it stops right after it says Video BIOS shadowed.
I have already tried pulling out the drives and trying to boot with less. And I have had no luck…
Any ideas?
  • Autonomix Oct 11, 2007
    No… it’s still locking up. I only have one chip of RAM in the system, and I don’t have any extra. I’ll see if I can get another chip to test with.
    Thanks for your help!
  • Autonomix Oct 15, 2007
    I pulled out the Hard Drive and tried to boot without it. It still locks up in the same place and i cant get into the BIOS.
Its an Hard disk problem;i have that issue before..its not a ram issue.
Posted on Oct 15, 2007
  • 1,006 Answers
You need to updrage you'r BIOS
Posted on Oct 12, 2007
    Problem Solver:
  • 4 Answers
With the power off, battery removed/no adapter plugged in, try removing and reinserting the RAM chips on the bottom. (they will have their own access panel. There will be a thin metal 'prong' on either side the holds the chip in place, gently push the open end away from the board to get it loose (it will pop up). gently lift out only touching the sides of the board. don not touch the chips or pins. Gently reinsert the way it came out. (you wont really harm the ram if you happen to touch it, but just to be safe as there is a slight chance). Once it is reinstalled and the cover back on, restart eh computer. If it still hangs, one or both chips may be bad. (this of course assumes you have 2 ram sticks and not one) It wont boot without one, but try booting with only one (if you have 2). If it were making it past the bios I would look more towards the HD, but with the Bios locking up I bet its just the ram needs to be reseated. post back if it still wont work/more questions.
Posted on Oct 11, 2007
SOURCE:
My toshiba satallite l300-20w turns on and says toshiba but wont load up or go to boot manager, at this point i cant do any thing the screen stays the same, what shall i do?
if you have more than 1 memory sticks installed try taking 1 of them out to see if it boots, if not install it back in then take the other 1 out. try to see if you can also go into system setup when you boot. or try clicking f8 bunch of times after restarting system to see if you can go into safe mode
May 24, 2011 | Computers & Internet
My toshiba satallite l305-s5909 wont display a screen. I turn it on and after the toshiba logo goes away the screen turns to black with a funny symbol and cursor blinking in the top left corner
Restart your laptop, as soon as it powers on (even before you see the logo), repeatedly tap on F8 to get to the advanced boot menu. Select the option for Last Known Good Configuration and see if it would boot up. If not, Repeat the procedure but this thime, choose safe mode. If you're able to boot to safe mode, you can just do a system restore to a date when it was working fine.
Apr 06, 2011 | Toshiba Computers & Internet
My toshiba satallite is not working
i think u should format your system sir.your os needs reinstallation
Mar 31, 2010 | Toshiba Satellite A105 Notebook
Won\t boot up and dont have start up disks
please give more details about the problem, like error messages, color of ecreen, beeps, etc.!
Jan 04, 2010 | Toshiba Satellite Pro L300 Notebook
My Satallite A100/A105 Laptop computer fails to come on at all.
Remove the battery pack and power up the laptop from the mains only....then replace the power pack when the machine has booted
Nov 24, 2008 | Toshiba Satellite A100-S8111TD Notebook
Locks up on boot
when it boots, press F8 select previous boot that worked...sounds like yu're having some disk issues, or you installed some driver that doesn't belong there...If it boots now, go to my computer, select the c drive with the right mouse, choose properties, choose options/extra check drive check both boxes and answer yes to a scheduled disk check. reboot the computer to fix the disk errors... what Pin Locked...
Jul 21, 2008 | Garmin nuvi 350 GPS Receiver
Toshiba A60 Not Booting
You might want to run a harddrive diagnostic test. You can find bootable iso's on the harddrive manufacturers website.
May 11, 2008 | Toshiba Satellite A60 Notebook
Toshiba Satellite A105 Notebook Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
