Question about Watches
Zegarek tcm 222197 - Watches
Dotychczas korzystalem tylko z czasu teraz chcialbym wykorzystac inne mozliwosci zegarka ale zgubilem instrukcje i nie wiem jak to zrobic prosze o instrukcje /zegarek z metalowa branzoleta/ chronograf
mcdevito75 here, You try, typeing in serach from your home page, Contact, then your watches name, then .com most watch manufacturers have a website.
Feb 09, 2011 | Watches
I have a black and dark grey digital watch marked TCM on the back with 4 buttons saying "bearing", "start/spl", "mode/select", "stp/light/set" around a circular digital face. On the back it says that it...
  1. Hold and press upper left. (backlight turns up and cipher (to adjust) start blinking)
  2. Switch between the positions by pressing bottom left
  3. Set the cypher you want by pressing bottom left
  4. Repeat step 2 and 3 each time you need
  5. Press upper left to end of adjusting
To use the compass - upper right. To callibrate and set the declination, please search it. I just post that answer to another TCM 217362 watch owner.
Oct 21, 2010 | Watches
I have a TCM radio controlled mans watch , I have replaced the battery now I cant put the watch at the right time can you help please
Sep 13, 2010 | Watches
Where ca I buy A new stainless steel strap and pins for my tcm chronograph quartz 20 bar watch serial number 234245
As long as it's not a strap exclusive to your watch, you should be able to take it to any jeweler who sells watches or a watch selling kiosk in a mall. I wouldn't take it to a store like Wal-Mart, just because they have no requirements for their employee's to know a crown from a clasp, for them to work in the jewelry area.
Jun 22, 2010 | Watches
WHERE CAN I BUY A NEW STRAP AND PINS FOT A TCM
mcdevito75 here, Any small watch repair shop in your area could help out.
TCM Digital Watch
v:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}w:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Cmpass (COM)
The integrated compass tells you the direction (e.g.SSW for south­southwest) as well as the number of degrees. To determine a direc­tion,hold the watch horizontally with the 12 o'clock position poin­ting in thedirection you want to know.
General information about the compass
The compass always points to the magnetic north pole.Maps are always drawn in alignment with the geographic north pole (verticallyupwards at 90 ). The declination angle denotes the deviation between themagnetic north pole and the geographic north pole. This deviation depends onwhere you are located. To obtain exact results, the declination angle must beentered into the compass.Remember to change the angle when travelling abroad.Within the UKthere is no need to change the angle because deviati­ons are only slight.Overleaf you will find a table showing the declination angles for a number ofcities around the world.A fault has occurred if the display shows"ERR" while taking a direction or calibrating the compass. Thecompass must be re-calibrated (refer to section after next) .
Table of declination angles
Amsterdam 01 W Little Rock 03 E San Francisco 15E Atlanta 04 W Livingston, MT 14 E Seattle 19E Bombay 01 W Munich01 E Shanghai 05W Boston 16 W NewYork City 14 W Toronto 11W Calgary 18 W Orlando 05 W Vancouver 20W Chicago 03 W Oslo 02 W Warsaw 04E Denver 10 E Paris 02 W Washington DC 10W Jerusalem 03 E Prague 02 E London 03 W Rio de Janeiro 21 W
Mar 05, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
