Question about Dishwashers
Actuator broke off from escutcheon
So today my GE dishwasher completely stopped functioning. Circuit breaker was not the issue. Opened the door by removing screws (after power is off, and watching some videos on the subject) and see that a part is loose. The part is the actuator for the switches. The actuator interacts with the door latch to activate the dishwasher when it the door is closed. When power is supplied and I manually depress the switches, the dishwasher begins to operate. So I basically just need to know the best way to reattach this actuator to the inside of the door. Aside from glue (which wouldnt last too long), or replacing the entire escutcheon, is there a simple way to securely reattach the actuator so I can wash my dishes?
  • David
    David Nov 26, 2013
    Here are pictures that show the problem, I appreciate any help.
  • David
    David Nov 26, 2013
    This is a GE model gsd2200g00ww, didn't seem to post correctly with the info I put in. Also sorry for the second picture, I shrank it a little too much to upload it. The picture is just trying to show where the plastic broke.
    Top Expert:
  • Dishwashers Master
  • 44,949 Answers
The actuator may only be available as part of a complete assembly. You might check with GE or an appliance parts supplier to find out.
Posted on Nov 26, 2013
  • David
    David Nov 27, 2013
    The actuator itself is not actually broken. The piece that broke is the screw mount that is part of the injection molded plastic that makes up the escutcheon. Parts sites say the escutcheon is no longer available.
No chime sound
If the appliance is eorking normally then the most likely cause is either, you have domehow, deactivated the chime in settings ( able to do on some makes) or the little buzzer in the programme unit has failed.
Jan 17, 2014 | GE Dishwashers
Dishwasher trips breaker. Breaker only resets of door is opened
wires rubbing inside dish washer , surprising its not blowing fuse in dish washer plug .
Mar 25, 2013 | Dishwashers
Our GE Profile dishwasher will not open. I have
door latch must have broke take a knife and jimmy the latch
Dec 10, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
GE profile PDW9880J00SS dishwasher just beeps
appears control is going bad,or problem with control circut
Oct 16, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
GE Model GHDA480N00WW non-responsive
Im having the same problem with mine.. Did you find a solution
Jun 23, 2009 | General Electric GHDA480N Built-in...
Whirlpool dishwasher du945PWPQ0 won't run, no led lights
If you have used a meter to check that the power circuit is live clear to the connection under the dishwasher then:
It is ~possible~ that (even though it is hard wired) a tripped GFI outlet in the kitchen has tripped and opened the circuit that this diswasher is connected to. Locate all GFI outlets in the house and reset them.
Seperate from that, you have a failed diswasher on your hands. If you have an extended waranty, well done. Otherwise, you need to decide between repair and replacement.
Mar 18, 2009 | Whirlpool 24 in. DU948PWPQ Built-in...
Dishwasher has no power. Running fine 'til this point...
Hi Dave
Make sure that with power off you check the interlock switch. When the door closes the actuator closes the switch(s) to continue power. Make sure that door strike is entering the latch assembly ok when the door is closed. Also with the circuit breaker off, make sure the wires at the junction box are in order. Here is the interlock switch assembly. Good Luck!!!!!!!!
Feb 26, 2009 | GE 24 in. Profile PDW8680JSS Built-in...
Blinking lights on control panel
Same issue, machine is about 30 days past waranty. Door switch broke, but of course they (GE repair) do not fix the switch, you have to order the Escutcheon Body (whole panel) to fix ~$350 total.
Apr 26, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Start button on the HMI won't work
There is a ribbon cable that connects to the control panel. Mine was operating the same as yours. I opened up the front and reinserted the cable and its been fine ever since. you need to take all the screws out from the door panel inside the washer to geet to it.
Nov 01, 2007 | GE 24 in. Profile PDW9800J Built-in...
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
