Question about Electrolux Zb2803 Unirapido Rechargeable Stick Vacuum Cleaner, Fresh Yellow
Batteries are dead will not recharge
Wont charge up think batteries are dead, can you purchase replacement batteries
    Problem Solver:
  • 12 Answers
I do believe the company sells their own batteries for your product and even if they dont, you can always buy them yourself.First look on the back of your product and see what size you will need.
Posted on Nov 27, 2013
Rechargeable vacuum cleaner, 2years old, battery will not charge, when in place for charging the middle light shows red for a while then goes out, filters cleaned all in place, any suggestions please?
When the batteries fail they typically do not accept and hold a charge which is the problem you now have.
If you can purchase a replacement battery, and as long as the batteries are replaceable in the appliance (some are not), you can run the cleaner again..
Dec 02, 2015 | Vacuums
My roomba irobot 700 series is completely dead after being disconnected for several weeks?
I noticed that when I started disconnecting my charger after it had recharged my Roomba, that it didn't run as long later. So I think that the Roomba needs to be sitting on the charger with the charger plugged in. I would put your's on the charger for two days and see if that does the trick.
How mechanically minded are you? Can you get a voltmeter and check what charge is coming out of your charger now? Can you access the battery and use a voltmeter to check what charge it has?
May 10, 2014 | iRobot Roomba 560 Robotic Vacuum
Dear Sir, Madam, I have a tooth brush by Braun : Oral B Triumph 5000. I am not able to recharge the battery any more.What should I do ? Thank you in advance for your answer. Best regards. GH. Leroux
Three possibilities come to mind ::
- the rechargable battery is dead and won't take a charge and needs replacing, or
- the charger is malfunctioning (broken wire or burned out transformer), or
- the electrical contacts on the toothbrush and the contacts on the charger are not making good contact (need cleaning or re-tensioning).
How old is the toothbrush ? Is there a charging light and does it light up when it's charging ?
Charlie
Feb 12, 2011 | Vacuums
I get a blinking yellow light when recharging my IRobot Roomba 550. What's wrong?
I am afraid you are having the problem of old or weak batteries. Old batteries at times tend to show such problems and do not show charge while charging properly. For this purpose, you can use a reliable Nicad Battery Repair Guide through which you can recharge the batteries without any problem and make them work like the new ones within no time, without anyone's help and you can do this all by sitting at home! I tried it and now I never buy new nicad batteries (http://www.nicadbatteryrepair.com/).
Jan 03, 2011 | iRobot Roomba 550 Vacuum
When to recharge batter
hi right to be honest both ways are correct, but if your using it every day then its best to put it back on the charger after every use, but the problem with this is that the battery never goes totally flat, so never does a full recharge this reduces the life of the battery by upto 50% so if you are using it regular and need it charged daily then its best to once a month let the battery go totally flat so that it wont even make a sound then do a full recharge.
Doing this will ensure the battery remains at peak performance and make it last longer.
If how ever your only using it say once a week then its best to only charge after the battery has gone flat due to the fact that it would remain on charge longer and cause the battery to over heat reducing the life span of the battery.
But witch ever method you use always let the battery go totally flat once a month then do full recharge this will prolong the life of the battery and ensure it keeps working at full power.
Let me know if you have further questions ok
Jan 18, 2010 | Euro-Pro Shark Cordless Stick Vacuum...
My roomba was not used for a month. Now it does
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Nov 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Model4210battry won't recharge, is it worth ordering a battery?
don't buy a new battery yet. you can reset the battery by charging for 16 hours, if this does not work, you need to take the battery out, push and hold the power button on your roomba for at least 15 seconds then reinstall the battery. plug in the charger directly to roomba not the docking station and charge until the battery light on the roomba is green. do not interrupt the battery charging cycle. after, leave the roomba charging for an additional 3 days or 72 hours. after, run roomba in max mode and run it till the battery is completely depleted. this will improve the battery overtime by charging again for 72 hours and depleting the battery. do this 3 or 4 times. and the battery should get better
Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Scooba not working after full recharge
NiCD and LiOn batteries have this tendency. They work great for a year, then slowly die off. The problem is you. When new, the device MUST be charged for 14hr nonstop, then every 2-3 months run dead, and recharged again 14hrs nonstop. This is done so the CPU of the Roomba (cool toy) KNOWS what DEAD is and what FULL is. It does this by measuring the amount of currrent flowing thru a very precise resistance. If you do hit and miss charge cycles of the roomba or leave it charging too long, it either develops a flase memory of the above two conditions, or gets HOT and the electrolyte paste dries out. Fix is to wear it out, charge 14hrs, wer it out againand repeat 3-4x. Then recharge and use. If that doesn't fix it, the batteries are too dried and need to be replaced.
Apr 08, 2009 | iRobot 5800 Scooba Vacuum
Hoover Freejet Cyclonic will not charge after battery run flat
basically, the batterie pack is shot and it will cost about £40.00 ish to replace. as you said, a right rip off
Dec 24, 2008 | Vacuums
Oreck Electrikbroom (battery) won't hold charge and pick up dirt.
Battery needs to be replaced. All rechargeable batteries have limited recharge cycles. NiCad's are usually used in these and also develop "memory' which keeps them from recharging fully.
Contact Oreck or reputable dealer for replacement.
Nov 15, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Electrolux Zb2803 Unirapido Rechargeable Stick Vacuum Cleaner, Fresh Yellow Logo
227 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
