Question about Home
Danco 4s 6h
I replaced both cartridges (hot and cold) and it is still leaking
    Master:
  • 796 Answers
Leaks are where the joints are not sealing and water escapes. When putting joints back together without adding a sealant or teflon (PTFE) tape, they will sometimes leak. Take the joints apart again and use a small amount of a paste designed to seal joints, spread on the threads of the joints. Tighten them firmly once and let the compound set for 10 minutes before turning on the water.
Posted on Dec 15, 2013
3 Suggested Answers
  • 129 Answers
SOURCE: my replacement danco 88675 posi-temp cartridge
Call a plumbing supply house in your area, they will be able to help you.
Posted on Sep 27, 2009
  • 28 Answers
SOURCE: I bought the Danco replacement
Sometimes on the stems on the side the handle attaches is a nut that can be tightened. Inside this nut is a rubber or other type of seal. tightening this nut stops the water from coming out of the handle. If the nut has already been tightened then possibly need to replace this rubber seal.
Posted on Sep 02, 2010
How to install a danco 10472 4z-24h/c hot & cold faucet stem
  • Shut off water supply
  • Open faucet
  • Remove knob
  • Unscrew old stem
  • Use flashlight to inspect seat for damage and corrosion. Dress or replace seat if necessary.
  • Install new stem
  • Reinstall knob
  • Turn on water supply and check for leaks
Feb 09, 2014 | Danco Faucet Stem
Valley 3Z-6H/C
Put the large part of the spring into the plastic or rubber washer first, then insert into faucet. I use a little of petrolem jelly for easy instlation.
Dec 22, 2013 | Danco Faucet Cartridge
Danco 4s 6h/c
Nov 26, 2013 | Home
3z-6h/c
change cold cartridge call danco if you can
Feb 10, 2013 | Danco Faucet Cartridge
I bought the Danco replacement stem for a milwaukee faucet(part 4s-6h/c) it is leaking from the handle... do I need to replace the plastic part that runs back into the pipe? Is there an easy way to remove...
Sep 02, 2010 | Danco Faucet Stem
Where does washer go for 12h-6h/c stem from Danco for faucet?
Is it brass, stainless, plastic or rubber? I think a stainless one might be for the knob screw, I don't think there is one inside, it might just have fallen into the pack. We get weird stuff all the time that doesn't belong. Hope this helps.
May 31, 2010 | Danco Faucet Cartridge
How to insert a hot cold ste, 3Z-6H/C FAUCET REPAIR
#1 THE FAT PART OF YOUR SPRING GOES INSIDE THE FAUCET ,AND SIT ON THE VALVE BODY(SEAT)
#2 THE LITTLE BLACK WASHER SIT ON TOP OF YOUR SPRING
#3 PUSH THE STEMS IN THE CORRECT SIDES HOT ON LEFT.CAUTION THERE IS USUALLY NOTCHES ON THE SIDES OF THE STEMS TO HELP YOU ALIGN THEM IN THE VALVE BODY,
4 PUT THE NUT BACK ON ,TIGHEN SLIGHTLY,TURN ON THE WATER TO CHECK ,IF OK RE INSTALL YOUE HANDLES
Apr 06, 2010 | Danco Faucet Cartridge
I bought a replacement Danko faucet cartridge for an american standard bathroom sink and the package said hot/cold but when I installed it on the cold side the handle turns the wrong way. How do I reverse...
Thae stem you got that said hot/cold were designed to fit old style cross handle faucets. So both hot and cold turned the same way. If the cold side you are replacing turns the opposite direction then you will need to get a cold stem. Danco does make them. Ask the retailer where you purchased the H/C stem. I hope this helps..
Dec 29, 2009 | Danco Faucet Cartridge
Home Logo
83 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
