Question about Cuisinart CWC1600 Wine Cooler
Condensor fan motor making noise on Cuisinart cwc-1600
Where do I get the part and how do I replace the condenser fan motor
2 Suggested Answers
SOURCE: Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Posted on Nov 03, 2009
My power supply keep on blowing fuse. I tried replacing fuse twice and immediately blown when plugin power. What could be the reason?
A dead short is more than likely. Potentially a shorted out compressor or wire pinched or a bad control board. I'd check the compressor terminals to ground, any motors to ground. With and without the wires hooked up to them. If the compressor or fan motors are grounded out it could cause that symptom. If you test them with the wires hooked up it will tell you if the wiring is shorted to ground.
Mar 24, 2016 | Cuisinart Cwc-1600 16-bottle Wine Cellar...
Why doesn't it cool?
If I unplug the Peltier the unit starts right up, the display working again and fans come on . Is Peltier shot ?
I also can't find the 4.5inch fans for unit Fan Model # SD1225S12L. What would happen if I leave Peltier unplugged ??
Dec 17, 2015 | Cuisinart CWC-1600 Private Reserve Wine...
Is there a replacement circuit board for the Cuisinart CWC-1600 unit?
The actual manufacturer of the circuit board out of China does not seek direct, but you may be able to order a replacement board through cuisinart support. More than likely your board is fine, but rather your power supply has failed. Check my post on how to replace the power supply for under $20
Jun 17, 2014 | Cuisinart CWC1600 Wine Cooler
My cuisinart wbc-1200 turns on and works but does not cool. how can i fix it?
I have the same problem. Fans worked fine. I took it apart and found bad thermoelectric cooling disk. Bought replacement on Ebay for $6.
Feb 01, 2011 | Cuisinart CWC-1200 Wine Cooler
How do i get the cabinet off to get to the fans on a cwc 900
You'll have to drill out the little plastic tabs which hide the star screws. I used a Dremel and a quick tap on each little tab to make a small hole, then pried out the plug. Then use a star tool (T10) to remove screws. The fans get dusty and sieze up. Lousy assembly to keep clean, but will be easier now. I had to replace the larger fan.
Nov 24, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Condensor sounds like it moans for a couple of seconds instead
Hello aeruslady1,
Do you mean the compressor? I'm sure you do. The condenser is the hot refrigerant line that comes off of the compressor.
It just sounds like you have an old compressor. I have seen them make noises for years before they take a dump. If it continues to run loud even after it starts however, then you may need to clean the condenser coil or replace the condenser fan motor. Another thing that might make it run loud is some refrigerant lines may be rubbing against something. This can be remedied by bending the lines.
Hopefully this helps.
Sincerely,
shays5415
Dec 03, 2008 | Refrigerators
WHIRLPOOL 2 TON CONDENSING UNIT
check wiring for condensor fan motor,make sure wire nuts and connections are tight,if still no luck then i'm afraid you have a bad condensor fan motor
Nov 08, 2008 | Whirlpool Heating & Cooling
Cuisinart CWC1600 Wine Cooler Logo
73 people viewed this question
Top Cuisinart Refrigerators Experts
Darrell
richie46
Are you a Cuisinart Refrigerator Expert? Answer questions, earn points and help others
