Question about Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5
Ingersoll rand t30 break in period? - Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5
  • 76 Answers
SOURCE: Ingersol T30 won't shut off and blows pressure release valve
the wire juction box on your compressor has a pressure switch that may be wound in to tight take the cover off the box there should be a switch with a machine screw with nut and washer and spring back this nut off and see if that helps if you go to far you just crank it back in until the switch hit although it may be the other way around you may have to tighten to lower the pressure some of them are made that way if this does not solve your problem send me a picture of the switch and can solve it from there
Posted on Jun 26, 2009
  • 583 Answers
SOURCE: ingersoll rand compressor T30 model 7100
I would wonder A if the wiring was heavey enough to carry that sort of load with out overheating B if the motor is big enough to do it for the same reason( ?what is the duty cycle?) C if the receiver is big enough to allow reasonable time between shut down and start up --- remembering that at start up the motor pulls double the current to start up and if it doesn `thave sufficient time to cool alittle before being called on to do it again and that would prompt the question ,does it have sufficient ventilation? these are all queries that would need addressing before I would try to offer a solution ,one thing is certain ,--there is something wrong
Posted on Aug 17, 2009
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
  • 1383 Answers
SOURCE: How do I adjust shut off pressure on an Ingersoll
The best way to go about the task of adjusting the pressure switch is to remove the cover to switch and note the brand/model number. Sometimes instruction are under cover of switch. With switch information, look for mfg. instructions. You will most likely see one or two springs with lock nuts. Do not turn them yet. Most pressure switches are sold with factory adjustment and are sold in pressure ranges. For two stage compressors as yours, the pressure is usually factory set at much higher (150-175) pressures than single stage which is usually about 120 -125. If you change the pressure setting it will also change the differential cut on pressure. The factory will actually use different springs to achieve desired pressures and are color coded. There are too many different brands of switches to recommend how to change pressure setting. You may discover that you can only change the pressure just a small amount (+or -15-20psi ). If you find the information about your switch, make sure that you count the turns exactly so that you can return to factory settings if things go wrong. You can extend the life of the comperssor by lowering the pressure as more amperage /heat is produced to achieve higher pressures. Good luck
Posted on Sep 23, 2010
  • 205 Answers
SOURCE: T30
If air continously comes from the bottom of the pressure switch (bleeder valve) you have a bad tank check valve. The check valve is located on the receiver tank where the copper line from the compressor head goes to the tank. The brass hex between the copper line and the receiver tank is the check valve. Remove it after making sure all pressure has been bleed off the tank. Then you can inspect it. I recommend replacing it unless there is something obviously stuck in it that can be removed with no damage to the check valve. Another way to see if it is the check vale is to loosen the nut on the copper line at the HP head that goes to the receiver tank. If air continously blows from the copper line the check valve is leaking.
Posted on May 05, 2011
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
SINGLE PHASE WIRING DIGRAM
You need a single phase motor to do that. A 3 phase motor cannot be made to run on one phase.
May 16, 2013 | Ingersoll Rand - Rand Type - 30...
I have an ingersol rand 2420n5 t30 and i want to convert it from single phase to 3 phase any help thanks
Hi robles212
To convert your T-30 to single phase you will have to do one of two things.
1. Change the motor to a single phase motor
2. Buy and install a "Phase Converter" to convert 3 phase to single phase
Please rate me
Bud
Oct 08, 2012 | Ingersoll Rand Type 30 Reciprocating Air...
Ingersol rand single phase t-30 compressor with twin cyl slow/ dragging
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
Jun 04, 2012 | Ingersoll Rand - Rand Type - 30...
How much oil for 2420N5
the price of t30 select is 6,000.00 pesos.
May 26, 2012 | Ingersoll Rand Type 30 Reciprocating Air...
What size breaker for 5hp motor? Ingersoll Rand T30 242-5d 1988
If its a 220vlt compressor a 60 amp twin breaker is recommended. good luck!
Aug 08, 2011 | Ingersoll Rand Compressors 5-HP,...
I have just bought an old ingersol rand T30 A2955 it has a knocking noise I would like to investigate it further but would like to have a manual handy before I strip it down do you know were to get one...
T30 compressors have changed very little over the years. You can use practically any t30 parts list for an aid in looking at how things line-up.
The link below is pretty much what you will find. Your local ingersol rand repair center will have parts and service manual for your unit. Easy way to look into interior of the pump without tearing many gaskets is to remove cylinder at the base of the pump. Quite heavy so you will need a lift of some sort. Good luck with your repair.
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-749.PDF
May 30, 2011 | Air Tools & Compressors
T30 lost pressure won't get over 100psi
I say head gasket leak or bad finger valve. Easy fix.
Sep 17, 2010 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5 Logo
41 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
