Our church has a GR3750 that has some sort of a power problem. When we push the power switch, the display lights for just a second and then goes out. Switching it OFF and then ON produces nothing. If we wait a while and push the switch, we will repeat the 'lights then goes out' sequence. We have the service manual with the Test Procedures but nothing covers 'No Power''. The technician for the local dealer thinks it is the power supply but they are not available any longer.
    Problem Solver:
  • 10 Answers
I think it is the fixing lamp may be broken or the theroswitch of the heater is cu of
Posted on May 09, 2009
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
All lights flash display reads "power out self reset in 10 seconds".
Display reads power cut restart in 10 seconds
The motor controller board has a switch mode power supply problem.
Best to get a new motor controller board Or a technician to look at it.
Look at the 6 digit part number under the bar code to get the right part for your machine.
Nov 22, 2013 | Fisher Paykel Eco IWL16
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
Riso graph GR3750 marca falla t11 necesito asesoria para solucionar este problema. O es necesario llamar a soporte tecnico ??
"Risograph GR3750 marks to fault T11. I need consultation to solve this problem. Or it is necessary to call to technical support?"
Error T11 means: Call service.
Here some details of the error which may help to solve it: Pressure Control Motor Lock • In 100ms from turning ON of the pressure control motor, the encoder sensor cannot detect a pulse. • In 5 seconds from turning ON of the pressure control motor, the pressure centering sensor is not turned ON/OFF. • When the fuse of the main power board is gone.
Feb 28, 2011 | Riso RZ220 Duplicator
I can hear my Ps3's Sound, when the HDMI cables are connected, and it's on the correct HDMI channel, though i can't see anything, the screen is just black. I have tried holding the power down, until i...
Ok, you are actually holding the power button down for too long. Please do the following to sort out the display on your PS3.
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep once when you first press it, then beep again about 5 seconds later. Release the power button when you hear the second beep. The display will now reset and it should detect your HDMI display with no problem.
Hope this helps
Dec 23, 2010 | Video Game Consoles & Games
Monitor-Gateway FFD1750;P/No 7005299 Power bottom malfunctions;push the bottom power bottom blue light is on and video is displayed for a second and the screen goes black. (Believe the problem is the power...
Could be Power Supply. If you get a least a little life then the switch is working. Guess if it goes out after you let go of the button... that could be the switch. If we are guessing and the PC is older than 3-4 years... I would think PS. A Motherboard switch is not mechanical... it is just a switch that if you short it once it is on... short it for 5 sec it is off.
Dec 29, 2009 | Gateway Computers & Internet
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Wiring two circuit pull switch boat lights
3 terminals.. 1 power input & 2 x outputs
Main positive goes to 1 terminal = power in to switch.
The anchor goes to another terminal = power out from switch to anchor
3rd terminal is another output for lights/anchor.
Mar 28, 2009 | Cole HERSEE PUSH-PULL SWITCH -- OFF-ON
DV100 Display
Hi questpilot,
what you're saying it can be 3 possible case
1.its the backlight that have problem and I give it 90% to your problem.The behavior of spoil back light sometime you can use and sometime you can't if you tab the switch that mean you power off the light and after that you power on it again so this will work for 1-2 second
2.Bad inverter or bad chip on that inverter this always happen but like this case sometime after switch, you can use for nearly a week or two. so I give it only 40% for your case.
3.Its the lid actuator but you already push it up and down already and still the same.and also when you push it down and up the light turn on...so I think this is working fine.
goodluck,takecare
May 16, 2008 | HP Pavilion dv1000 Notebook
k24674
jasbo
jasbo
