Question about Haier hwr10xc6 Air Conditioner
Haier heating cooling system not working - Haier hwr10xc6 Air Conditioner
    Master:
  • 571 Answers
Try the GFI reset in the cord.
Posted on Dec 07, 2013
Haier AC window unit showing code "EO"
It's a "drainage system trouble" code.
The compressor run light flashes in 10 flash increments.
You should be able to check whether condensate is draining from the unit.
If not draining, that's your problem.
Sep 13, 2017 | Haier Heating & Cooling
My haier hpp12xct-lw is accumulating water in air mode
So it's likely not fully evaporative. Must be high humidity and auto evaporate can not keep up. It just means your unit is working great. Drain it!
Aug 10, 2017 | Haier Heating & Cooling
My haier ac is not cooling the room.i have changed its temperature to 16? but it remain on 34 and it also producing sound...what can i do now ...is this voltage problem or deficieny of of gas
If not working way it used to measure the voltage to eliminate that from the equation. If voltage is ok, and amperage usage is lower that normal, loss of refrigerant is suspected.
Jul 17, 2017 | Haier Heating & Cooling
Amana PGD60C1152E no heat
Your thermostat Function 0170 must be set to "1" for Single Stage Heat/Cool. Function 0180 must be set for "0" for Heating Fan Control. Function 0240 must be set for "5" for the Heating Cycle Rate for your <90% Gas Furnace. If you have already done these steps or if, after doing these steps, you continue to experience a problem, you problem could be with your Gas Furnace. I'm including some links for information on your system and thermostat that include wiring diagrams.
http://johnstonesupply9.com/TechDocs/Amana/Package%20Units%20Gas-Electric/PGD%20Pkg%20Gas%20Ele/PGD%20Tech%20Info.pdf
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2206EF.pdf
Mar 06, 2010 | Amana Haier AP125HD Air Conditioner
Runs but does not collect water. Humidity is not going down.
It is possible that the cooling fins are not working due to insufficient coolant or the compressor system is faulty. Basically the fan pulls air across a cooling fin . Moisture from the air then condensates and falls into the pan as water. The air is then heated before it exits into the surroundings. The fact that there is no water collecting suggests that the cooling stage is not working. I see from other posts that there is a fuse somewhere. Maybe this fuse is blown and is associated with the cooling compressor..hope this helps
Jul 19, 2009 | Haier HDN655E Dehumidifier
Central air and heating, not cooling
Need to have checked out by a diagnostic ac man.
Aug 08, 2008 | Haier Energy Star ESA3183 Air Conditioner
I have a Haier 18 bottle cooler. And while it keeps the wine cold, it almost never shuts off. I rarely open the door to let the cold out, but the refrigeration unit never stops pumping. The fans are...
No, i don't believe u are. these small fridge will run longer during the day as they have limited cooling capacity and the heat load is higher during the day. there could also be a problem with the cooling system and if there is one, the problem will become more noticeable and it will stop cooling. otherwise, i would leave it as is
Jul 21, 2008 | Haier Refrigerators
Haier hwr10xc6 Air Conditioner Logo
23 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
