Question about Siemens Gigaset 8825 Cordless Phone
Siemens gigaset 8825 handheld phone
I need to purchase another handheld and charger to go with it.  Any out there?
  • Susan Beth Oct 11, 2007
    I haven't received any responses, is this how this site works?  I saw other people's questions with replies; that's what I'm looking for - a vendor where I can buy one more handheld set for my Siemens gigaset 8825.  Thanks, Susan Gregory
    Novelist:
  • 106 Answers
Yes you can go to www.cordlessrepair.com for all your Siemens purchasing and repair needs.
Posted on Feb 11, 2008
SOURCE:
Gigaset 8825 answers phone but does not record message
Some Gigaset phones have an option to have the answering machine play an outgoing message only without taking a message. You should check your settings and make sure you don't have yours set up this way. This could also happen if the memory for the answering machine is full so that it cannot record any more messages.
Sep 01, 2014 | Siemens Gigaset 8825 Cordless Phone
I have a gigaset 8825. I have a "distinctive ring" problem
I have the same phone system, and *think* you may be able to fix the problem by adjusting the amount of rings before answer on each unit. This assumes there is an auto answer system engaged. Hope that helps some.
Ken Lundberg
Jun 19, 2009 | Siemens Gigaset 8825 Cordless Phone
Siemens gigaset 8825 has a problem with the base unit
http://kb.efficient.com/display/1n/index.asp?c=&cpc=&cid=&cat=&catURL=&r=0.5180628
Jan 08, 2009 | Siemens Gigaset 8825 Cordless Phone
Gigaset 8825 cordless phone pin reset
The default PIN for base and handsets is 0000 - if it has not been changed
  • Press Menu on Handset
  • Scroll to Mobile Settings - press ok
  • Scroll to Local Settings - press ok
  • Scroll to Chang Pin - press ok
  • Enter Current handset PIN - press ok
  • Enter New PIN - press ok
  • Display will show Confirm - Reenter PIN - press ok
Sep 15, 2008 | Siemens Gigaset 8825 Cordless Phone
Gigaset 8825 new
They are not manufactured anymore, but you can buy used ones off Ebay.
Jul 07, 2008 | Siemens Gigaset 8825 Cordless Phone
System pin unknown
I will email you steps to restore factory default PIN...send me a note
Nov 20, 2007 | Siemens Gigaset 8825 Cordless Phone
Power supply gigaset 8825
The power supply for the 8825 base is to be 13 volts AC, rated at 850 milliamps or higher. You can go anywhere from 13 up to 15 volts without hurting the unit, and a higher current rating is even better. We actually make them ourselves through bulk purchases of varieties of power supplys. Your next delimma will be the plug size, it is a pretty common size, most universal adapters will have the right size of the outer and inner connections.
Nov 16, 2007 | Siemens Gigaset 8825 Cordless Phone
Beeping Handsets
Mine have done that as well.
After cleaning the contacts on both the handheld unit and the base itself, it seems to stop the problem. Try using a qtip that is wet with water or alcohol.
Oct 10, 2007 | Siemens Gigaset 8825 Cordless Phone
Gigaset 8825
You can download the manual from the link below: http://www.barclayent.com/manuals/Gigaset%208825%20Full%20Manual.pdf You will find how to use the answer phone remotely on page 60. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Siemens Gigaset 8825 Cordless Phone
You can download the manual from the link below: http://www.barclayent.com/manuals/Gigaset%208825%20Full%20Manual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Siemens Gigaset 8825 Cordless Phone Logo
312 people viewed this question
Top Siemens Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
