Question about Ativa AVR1 Digital Answering Machine
How do i record a new message - Ativa AVR1 Digital Answering Machine
KXTG9341 Top light flashing and 'New Voicemail' message on handset display, but no new message recorded on the answering machine.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone.
Please contact your telephone company for instructions on accessing their voicemail system.
Feb 27, 2014 | Panasonic DECT 6.0 Expandable Cordless...
How do i change the message on my answering machine
Hold the announcement key down. If the old message is there it will read it out loud to you. If you wish to change it, just hold the announcement key and speak over the old message. Make sure you keep holding the announcement key as you record your new message. When you have finished recording, release the key. If you wish to hear your message push the announcement key again. Do not hold it down this time. If you are not satisfied with the new message, repeat the method by holding down the announcement key again and recording your message. Your old message will disappear once you have recorded your new one.
Jan 07, 2013 | Vtech DECT 6.0 Digital Cordless Phone
How do i get messages from remote location
To use your system from a remote telephone, you must first enter a 3-digit remote operation security code. The security code label is located on the bottom of the system.
1. Dial your phone number.
2. When your outgoing message is playing, enter your remote operation security code. Bd appears on the display to indicate the system is in remote mode.
If there are no new messages, you hear three beeps.
These are the remote codes available to you:
2 # Play all messages.
2 5 Play new messages.
3 # Delete all old messages.
7 # Record new outgoing message.
7 # Stop recording outgoing message.
8 # Record memo.
8 # Stop recording memo.
9 # Turn system off/on.
0 # Monitor the room..
Jun 12, 2011 | Radio Shack 3822 Digital Answering Machine
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
I recently bought a dect 6.0 digital answering system,and a friend put the first message on for me,then lost the manual,and now I can't figure out how to record a new message.Help!
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
  1. Press /mute. The system announces the number of new and old messages, then starts to play themessages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that thesystem is in the command waiting mode.
  3. Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the announcement.
  4. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recordedgreeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time.
  1. Press the Message icon (letter)/mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
  3. Press 6. The system plays the current greeting.
Jan 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
Jun 23, 2009 | Nokia Cell Phones
1726 does not record messages
System will not record messages
When memory is full, saved messages must be deleted before new messages can be recorded.
If RO (announce only) is selected, no messages will be recorded.
Jan 15, 2009 | AT&T 1726 Digital Answering Machine
NEED TO RECORD NEW ANSWERPHONE MESSAGE ON ONETEL OT150
To record a new OGM, on the Onetel OT150
Press "menu" on the base unit, then "up" once to record OGM 1 or twice to record OGM 2.
Press "OK" The existing OGM will begin to play. Whilst this is playing press and hold "MEMO"
Record your message, speaking close to the base unit. Press "stop" (square) when finished.
If you decided you don't like your message then, repeat the process above but when it tells you to record your own message press "stop" (Square) and the default will be reset.
Jun 11, 2008 | Cable_and_wireless CWD4901 Cordless...
To record a new message on my Sharp UX 265
press OGMn key
select O x general outgoing message
pick up handset and record your message (max 60 seconds) (best 30 seconds
recommend pause 2 seconds before starting recording.
press stop when finished.
press OGM to listen to recorded announcement. redo as above if not happy w it.
Cheers
ojgv@comcast.net
Nov 28, 2007 | Office Equipment & Supplies
SW Bell FA-980 Answering Machine
Here is a link to a similar model: http://www.swbfreedomphone.com/ib/ibansw/fa970.pdf Here is what it says: TONE REMOTE OPERATION Remote Security Code To access answering functions from an outside line, you will need to enter the three digit security code located on the bottom of your unit. Write this number on the Remote Access Card, which you can keep in your wallet. Remote Turn On If you forget to turn on your unit: 1. Call your unit from a touch-tone phone. 2. Wait 12-14 rings until the machine answers. 3. The FA970 will automatically answer by playing your greeting. You may hang up the phone, and subsequent calls will be answered. Remote Message Playback 1. Call your unit from a touch-tone telephone. 2. After your FA970 answers, it plays the outgoing greeting and beeps once. Dial your three digit security code within 20 seconds after the beep, pressing and holding each digit for 1-2 seconds. Allow a 2 seconds interval between each digit. 3. Your FA970 will sound one beep to indicate the code was entered correctly. (If there are no beeps, enter your code again.) 4. You can press the following buttons on your keypad: Option Press Playback Mailbox 1 Messages (1) Playback Mailbox 2 Messages (2) Record Memo Message (3) Record New Greeting (8) Turn Off Answer Mode (9) If you press ?1? or ?2? (to playback messages), you have the follow options: Option Press Erase Current Message (0) Repeat Current Message (4) Repeat Previous Message (4) repeatedly Stop Message Playback (5) Skip to Next Message (6) To SAVE messages, hang up the telephone. Note: Your FA970 will sound a series of beeps if there are no messages. Remote Record New Greeting If you press 8 (to record new greeting): 1. When you hear a beep, begin recording your new greeting (up to 30 seconds). 2. When you have finished recording your new greeting, press (5). The unit will beep, and the new greeting will playback to you. 3. Hang up the telephone. Remote Record Memo If you press 3 (to record memo message): 1. Within three seconds of pressing ?3?, press ?1? or ?2? to select Mailbox 1 or Mailbox 2. Otherwise, the memo will be recorded in Mailbox 1. 2. When you hear a beep, begin recording your memo (up to 60 seconds). 3. When you have finished recording your memo message, press (5). 4. The corresponding Mailbox message count will be increased by one. To Retrieve Messages when Recording Memory is Full 1. When the message capacity is full, the unit will sound 3 beeps after answering the phone. 2. Within 20 seconds after the 3 beeps, dial your 3 digit security code. 3. Your FA970 will sound one beep to indicate the code was entered correctly.
Mar 22, 2007 | Southwestern Bell FA970SN Digital...
Ativa AVR1 Digital Answering Machine Logo
Top Ativa Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an Ativa Lands Phone Expert? Answer questions, earn points and help others
