Question about Kenmore Sewing Machines
I have a kenmore model 385.15516000 it seems to be running in reverse the hand wheel turs counterclockwise while running and feeds the fabic toward you makes no difference if you hold down the reverse button
SOURCE: reverse on kenmore sewing machine 385
I recommend that the machine be serviced by a professional but if you're handy it may simply need cleaning around the reverse cam. To do this place the machine on it's back. You'll need to access the rod that drives the feed dogs and cam mechanism by removing all screws holding the bottom plate of the machine. Remove the bottom plate. Note that when you push the reverse button, while turning the wheel a thin rod moves left which allows a plastic cam mounted to the cam rod to also move left and engages the feed dogs in reverse. If the cam is not moving enough or if too slow, it may be that the rod and cam need cleaning and lubrication. Clean out all lint and lubricate the cam where it moves on the shaft. Try to get it to move more freely without forcing it. When done replace the bottom plate. I just repaired my wifes machine and this solved the problem. Hope it helps.
Posted on Feb 17, 2008
  • 19 Answers
SOURCE: My kenmore 385 won't feed fabric
hi there check feed dogs are up not down mary h
e
Posted on Dec 30, 2008
  • 323 Answers
SOURCE: feed dog not pulling fabric
First, remove the needle plate and using a small screwdriver, clean the packed lint from in between the teeth.This will allow the teeth to go up.
sewman7
Posted on Mar 20, 2009
louislevel_2
  • 374 Answers
SOURCE: Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Posted on Apr 03, 2009
  • 323 Answers
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
Posted on May 16, 2009
How do I remove the bottom plate off of A Kenmore 1941 sewing machine? I removed all the screws and it still want come off.
1. Slide the front plate towards you. (Don't remove)
2. Lower feed dogs by rotating the hand wheel.
3. Raise the pressure foot or totally remove.
4. Remove the plate under the feed dogs.
5. If you remove the front plate it can be replaced at an angle. (Flat like paper) There are springs under the plate that must catch under the main frame of the sewing machine. Twist the plate until straight and push into position.
Nov 10, 2015 | Kenmore Sewing Machines
I can not raise the feed dogs on my New Home Model SS2015 machine even when following instructions -- push lever in direction of arrow illustrated. Help! Thanks!!
On sewing machines, when you lower the feed dogs the machine lowers them immediately. However, when you RAISE them, you must turn the hand wheel TOWARDS you several times before you hear them click into place. ALWAYS turn the wheel towards you for anything.
Nov 09, 2015 | New Home Sewing Machines
Reverse button won't work. Anh trouble shooting tips?
This button simply reverses the action of the feed dogs of the machine. Remove the thread plate and all the mechanism (bobbin, bobbin holder, etc) you can in the bobbin area. This should give you a better view of the operation of the feed dogs. Rotate the machine with the hand wheel to see how it operates. Continue rotating the hand wheel and push the reverse button. See if you can spot what's preventing the feed mechanism from reversing its rotation. Hopefully it's as simple as material or thread buildup in the mechanism.
May 29, 2015 | Sewing Machines
Can not raise feed dogs
They WILL come up for you, and here's how. You see, anytime you put the feed dogs down they go down right away. But when you put them up again, you have to turn the hand wheel TOWARDS YOU (ALWAYS TOWARDS YOU FOR ANYTHING) at least one or two times before the dogs come up again. You'll hear them "snap" into place, but until you do that, they won't move at all, on ANY machine I'm familiar with.
A word about pulling the hand wheel towards you. If you turn it away from you for more than one revolution, you run the risk of throwing off the timing. I was told this by a technician of many years experience many years ago.
Sep 12, 2014 | Sewing Machines
I can't get my feed dogs to raise. Is there a screw adjustment?
Chances are, your feed dogs raise just fine, but here's the problem. In addition to raising it with the lever, button, or dial, you have to bring the hand wheel TOWARDS you (ALWAYS towards you for ANYTHING) at least one or two revolutions before it will raise and snap into place.
This is true of every machine of every model, by the way, and I have a friend that brought a brand new Brother dirt-cheap from WalMart that was being sold as defective because the feed dogs wouldn't raise. She got it home, flipped the lever, turned the hand wheel two revolutions, and . . . VIOLA! She got a perfectly good brand new machine for practically nothing!
Jul 06, 2014 | Singer 7444 Mechanical Sewing Machine
I have a singer cxl electronic sewing machine and i have a problem with the needle either not moving or stopping when stitching the larger motifs or the zigzag stitch, somtimes the needle jut moves too...
The needle either not moving or stopping is a sign that the machine is jamming. Here's the answer for the question "My machine is jammed" from the FAQs on Singer's web site at http://www.singerco.com/support/faqs.html
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Your description of the needle hitting the plate or foot is an indication that the machine's timing has become unaligned which can be caused as indicated above by turning the hand wheel away from you - the correct way is to *Always turn the hand wheel towards you.
Mar 03, 2011 | Singer Sewing Machines
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
The thread hangs up inside the bobbin holder
Sep 26, 2010 | Singer 2517 Mechanical Sewing Machine
h! there,
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Sewing Machines Logo
264 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
