Question about Toshiba Satellite L775-S7350 17.3" Notebook PC - Aluminum Blue
Red line on my display
I have a vertical red line and a white horz. dash line on my display
    Champion:
  • 219 Answers
Sounds like you have a bad video card
Posted on Nov 27, 2013
Left side of display has flickering vertical lines
Bad video driver chip for that location. Needs to be serviced.
Jan 14, 2014 | Samsung LN-S4051D 40 in. LCD Television
Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Jul 21, 2010 | Toshiba Computers & Internet
Hi, Two sets of lines have appeared on the screen
are these lines vetical or horz if they are vertical your panel has failed and will need to be replaced big bucks if they are horz , then it could just be the T-con board and you will need a tech to confirm this I have seen this problem cause by a poorly seated connection
Dec 07, 2009 | Televison & Video
I have a good picture then it goes horz. with static and then a good picture and then a horz. lines and static about every sec.
The horizontal line indicates failure of vertical section, checkout the output capacitor of vertical-section connecting to the yoke (vertical) for any loose contact, dry solder, capacitor wear-out.
Need to check the register and filter capacitor that powers the vertical-section.
Sep 28, 2009 | Sanyo DS25390 TV
My lcd tv has red and green lines in it
if they are pixel wide and vertical your panel has been hit or just fail
if not on warr buy a new set very expensive if they are horz side to side the t-con board has gone bad..either way have it looked at by a pro
Sep 16, 2009 | Proscan 42LA45H 42 in. LCD TV
Vertical line in center
If the line is "vertical" then the vertical circuit sounds OK. The problem would be in the horizontal deflection.
Check yoke connection and solder around horz defl circuit.
If the line is horizontal then I would suspect the vertical IC.
Apr 02, 2009 | Sanyo DS31520 31" TV
I got white vertical line running down a plasma display panel . they are close together that you cant even see on that side of the tv. on a closer inspection they are blue-green-red-blue-green-.... but...
A vertical line running down a plasma display can be caused by :
faulty buffer module.
Fauly sustain card.
Faulty plasma display.
Try unplugging power cable and see if this helps, if it does not , then you will need to call a technician.
In that case call the support number listed on your owner manual.
If warranty has expired, ask for a warranty extension, if available. this is cheaper than repair cost, and will cover the repair.
Jan 04, 2009 | Sony PFM-50C1 50 in. Plasma HDTV
Vertical blue line in display PS3
Alright, I do believe i have a solution. But i need to know the brand of TV you own, how old it is, and If your using an adapter, or the regular "Yellow, Red and White" cords.
Nov 29, 2007 | Sony Playstation 3 (PS3) Console
Re: ask assistance
caution reduce brightness to protect crt burn. vertical line with sound ok is due to 1 deflection coil connector loose or wire going to horz.coil disconnected. 2 capacitor going to h/winding loose or defective. 3 print break from eht to h/coil.
Sep 29, 2007 | Televison & Video
Toshiba Satellite L775-S7350 17.3" Notebook PC - Aluminum Blue Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
