Question about eLocity A7 tablet Android
A7 does not turn on power light only blinks - eLocity A7 tablet Android
My tablet when turned on it gets stuck in android and doesn't want continue. I had searched and I need the rom update and I Don't find it
I would reset it. some have button in a hole
or turn off hold volume down and power at the same time till menu appears or you vibration then release
or turn off hold volume up and power at the same time till menu appears or you vibration then release
Jul 10, 2015 | SVP 10 Inch Dual Core Dual Camera ANDROID...
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
Sep 01, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Why is my power light blinking red on my coby tablet?
You won't find a manual. Coby went out of business several months ago. It might be time to replace it. Sorry.
Aug 02, 2014 | Coby MID70244G 7 KyROS TABLET TOUCHSCREEN...
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 20, 2013 | Coby kyros Tablets & eReaders
Kindle light is orange when I charge but even after of hours of charging continuous efforts to turn on Kindle, it won't turn on.
Try to slide and hold the on switch until after the power light blinks three times (should happen after a little more than 5 seconds). Release the switch after the blinks and the Kindle should start up.
This is only necessary if the Kindle was switched off by the same method before, or if the battery was completely drained. A short nudge of the power switch merely puts it in and out of a power-saving sleep mode, the prolonged hold really cuts / reinstates power.
Jul 16, 2011 | Amazon Kindle Wireless Reading Device
When I picked up my Kindle to read it today, the screen was on and frozen. I tried to turn the page and nothing happened. I tried turning it on and off and nothing happened. My husband held the power...
Your husband switched the device off. If you give the power switch a short nudge only, it goes in and out of "stand-by" mode, it is not really switched off.
Try to slide and hold the power switch again, until after the power light blinks three times. Should happe after ~5 seconds of holding. The Kindle should restart now --- takes about a minute, but you will see a progress bar to keep you happy during the delay.
Jan 11, 2011 | Amazon Kindle Wireless Reading Device
My hp paviliOn tx2500 touchscreen laptop monitor will not turn on. The caps lock and numb lock lights flash on and off, and the blue lights around the screen work, and I can hear it turn on, however the...
cap lock & num lock flashes are an error codes
LEDs blink 1 timeCPUCPU not functionalLEDs blink 2 timesBIOSBIOS corruption failureLEDs blink 3 timesMemoryModule error not functionalLEDs blink 4 timesGraphicsGraphics controller not functionalLEDs blink 5 timesSystem boardGeneral system board failureLEDs blink 6 timesBIOSBIOS authentication failure
Jan 03, 2011 | HP Pavilion tx2500z Tablet PC
When I turn on M275 I get power light, hard drive
I have the same M275 tablet and was looking for a solution when I came across your post. I couldn't find a solution so I went over every nook and cranny of my tablet and found my hard drive was not completely pushed in. I pushed it in tried the power button again and it worked! I am shocked because my laptop has been down for a year now. I thought maybe it was a motherboard problem and it was junk. I'm so excited. Anyway all I can suggest is check that the hard drive on the right side is completely plugged/pushed in. I hope that works for you.
Feb 06, 2010 | Gateway M275 Tablet PC
Satellite A45 S150
hold it down for 10 sec.
if that doesn't work remove battery and try again
Dec 29, 2007 | Toshiba Satellite R10-S802TD Tablet PC
eLocity A7 tablet Android Logo
32 people viewed this question
Top eLocity Tablets & eReaders Experts
Are you an eLocity Tablet and eReader Expert? Answer questions, earn points and help others
