Question about Dewalt DC011 AM/FM Radio
Dewalt transformer l4821 a16e-v - Dewalt DC011 AM/FM Radio
My Dewalt dc012 radio will not work while plugged in, it only works with a battery
There is a small transformer which is used to lower the voltage for the radio to use (12 Volts I think) These transformers have been known to be defective at times. You can pick one up at the Dewalt store for about $25.00 and install it yourself.
Dec 29, 2012 | Dewalt Dc012 Worksite Radio With Built-In...
Lenovo think centre 9277-A16 sound drivers
how to download sound driver lenovo model no M/T 9277-A16
Sep 10, 2011 | Computers & Internet
Charger not charging,charging led not lite. Reading approx 3.2Vac out of terminals. On a good charger the reading is 4.8Vac Dewalt Charger ( Model DW9118) 7.2V-14.4V
You can try warranty services. However, if they are having an event in your area you might just try going down there. I have taken bad batteries to them in the past and they just GAVE me a new one.
http://dewalt.com/events.aspx
May 04, 2011 | Dewalt Drills
My Dewalt DC011 has now got another fault. Recently had the internal transformer changed under warranty. But now have noticed after using it for a couple of weeks olugged it in and it started making a...
The original problem that damaged the internal transformer was not resolved. The transformer may be damaged again - it is used in the AC circuit but not in the battery. They are two different circuits. The red led is part of the AC. I would contact Dewalt and send it back explaining what happened. The part they replaced should be under warranty.
Feb 23, 2011 | Dewalt DC011 AM/FM Radio
Dewalt DCo11 worksite radio W/ charger. Only works with batteries. No 120 V. Checked fuse. OK
Check to see if you have voltage out of transformer, more than likely you won't, if theres no voltage out of your tranny it needs a replcement.
Oct 30, 2009 | Dewalt DC011 AM/FM Radio
Hi ya my dewalt radio will not power on but still charges the battery
You are lucky it still charges battery. Your transformer for the radio has a fuse on the winding, this has gone or the transformer has gone.
Jul 11, 2009 | Dewalt DC011 AM/FM Radio
Dewalt
Hi there!
I am afraid you can't do that by the changing plug. However, you can do that by using a Step-down Transformer which will bring 220V to 110v that is what your machine is designed to run on. Check the wattage of your drill before getting a Xformer. Usually the stepdown x-former should have a proper socket at the output side. Good luck.
Gamba
Jan 29, 2009 | Dewalt 18 Volt Compact Drill Kit
Changing Dewalt charger from 120V to 240V
all i can say get a seperate step up transformer fron 110v to 220v.then just plug in charger to the step up transformer. make sure that u have 2 consider the frequency in ur country.
Jul 03, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Only works with battery, wont charge no sign of power. fuses are fine
ive got the same problem checked resistors and circuit boards cant figure out .let me know if you find out whats wrong
Dec 22, 2007 | Dewalt DC011 AM/FM Radio
Dewalt DC011 AM/FM Radio Logo
314 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
