Question about Fedders Heating & Cooling
FEDDERS ductless Split A/C (1FC1009N2FUL). The indoor AC unit is covered with frost. Code 'E3'
I bought a house with a FEDDERS ductless Split A/C (1FC1009N2FUL). I was not paying attention when the seasons changed. It is now below freezing outdoors. I find the indoor AC unit is covered with frost and I can see frost covering the path from the outdoor unit to the indoor unit. There is a code 'E3' on the indoor unit. The outdoor unit fan is running. I wonder if it is trying to defrost? How can I shut it off for the winter? and should I cover it for weatherproofing?
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
greenspan
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
  • 182 Answers
SOURCE: i have a friedrich ductless
not able to find the error codes for the unit number you gave but, here is a number you can call to get them. sorry not more help.
1-866-793-0323 spacer.gif Mon - Fri 9:00am to 6:00pm EST
Posted on Dec 20, 2010
  • 4 Answers
SOURCE: lg split ac outdoor unit delayed start
acctullly when indoor unit on then outdoor unit take 3 to 5 minut taking on.
and secondly when indoor unit regain its temoerature as we set on indoor ac then it trips the out door unit.
when 3 to 4 degree exceed the temperature then it again start the outdoor unit.
reply if u understand
zil.muhammad@yahoo.com
Posted on Jun 09, 2013
Fedders Air conditioner
Try a hard reset first.Disconnect the machine for about 30 minutes and reconnect after that to see if the issue is resolved.
Jun 07, 2008 | Fedders A6P09S2A Air Conditioner
Panasonic mini split air conditioner css9nkua. what does run code h99 mean?
H99: Indoor heat exchanger anti-freezing protection
Causes: - Insufficient refrigerant;
- Air filter dirty;
- Clogged cross flow fan.
Apr 29, 2015 | Panasonic CS-S9NKUA Ductless Mini Split...
Change thermostat 1998 grand marquis
Locate the water hose at the top of the radiator and follow it to the top of the engine block. There you will find the thermostat housing. Remove the two bolts and remove the housing. Pay attention as to how the thermostat is sitting in the housing. Lift it out and put in the new thermostat the same way. Make sure you replace the thermostat housing gasket. Reassemble the housing and add anti-freeze until full.
Apr 11, 2010 | 1988 Mercury Grand Marquis
Where can I get a remote for a Model ASORD18DA Ductless and a service manual.
Hi; Look in the Yellow Pages for Your local ac supply house they can order it for You or point You to the manufacture for assistense...alpharome416
Feb 18, 2010 | GE Quiet-Aire Ductless Heat Pump Split...
Mini split AC's
they are excellent and very efficient sytems
i have a muti pass ductless in my home and swear by it so much i went to school for them
I am now a mitsubishi cert expert
and cannot sing the praisees high enouhg for the ductless systems
Jun 14, 2008 | GE Quiet-Aire Ductless Mini Split System...
Heating & Cooling Logo
57 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
