Question about E-Machines T5048 (7136) PC Desktop
I have a emachine 4010. Monitor display sideways
I hit a key on my emachine keyboard and my monitor went sideways. how can i correct?
Hold alt+ctrl then click the up arrow while holding alt+ ctrl
Posted on May 08, 2009
Monitor does not light up at all.
Did she spill something on it? Have you tried to make sure it's not an issue with your bright and dark buttons or keys on the keyboard?
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 08, 2012 | Gateway 400SD4 Notebook
Screen dark
Have you tried to brighten it by the keys on the keyboard? Most times you have to Press and Hold the FN function key located at the lower left portion of the keyboard then hit the key that brightens the display.
If that does not work then try the steps below.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 30, 2012 | Computers & Internet
I was dusting my acer monitor and microsoft wireless keyboard and i must have hit something because now my monitor is reading sideways and the mouse wont work with it either. Can you tell me what I need to...
Sounds like you changed the orientation of your display settings from landscape to portrait.
In Windows 7 you can go to the control panel, choose display and click "Change Display Settings" on the left side.
From there choose the "Orientation" dropdown and change to your desired setting (most likely landscape)
Good luck
May 12, 2011 | Acer AL1916W 19" LCD Monitor
I have a problem with my computer emachines j4501 desktop pc windows vista home premium..after the windows logo the monitor turn blank...but the cpu is still on.... what will i do...
If you can see the windows logo screen both your computer and monitor is working, possible problem could be that the display settings are set to high that your monitor is unable to handle it. Restart computer and keep tapping F8 key. This will take you to the advanced options menu In the list of options here choose enable low resolution mode and hit enter (you can only use your keyboard to choose - use the up / down arrow key) once you enter windows low res mode change it to 800 X 600 and restart the computer Once you are in the right mode now change the display settings accordingly.
Mar 12, 2011 | E-Machines eMachines Desktop PC
The screen is turned sideways
It sounds like you accidentally press the key combination to rotate the screen. This is a feature on some video cards to allow portrait display with the right monitor. Your monitor does not rotate so the picture is sideways. To correct this problem simply click CTRL + ALT + Up Arrow and your screen should return to the correct orientation.
I hope this helps, if so please rate our solution.
BuddyMc
Dec 22, 2010 | Dell E173FP 17" LCD Monitor
The monitor volume display is popping up and i can't get rid of it.
Check your display buttons along with the keyboard and mouse, to see if you have any key stuck down, or being pressed. Is there any other devices connected to the emachine that could be causing this behavior?
Dec 18, 2010 | E-Machines eMachines Monitor E15T4
Monitor display is sideways not vertical
with some graphics card you can rotate the display try pressing ctrl and the alt key at the same time and while doing this hit the arrow key (or direction) that u want the bottom of the screen... so if u want ur screen upside down, hit ctrl alt and the up arrow
Aug 13, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
XEROX LCD flat screen monitor
Hold down the combination of keys "CTRL"+"Alt"+ "arrow keys" to change picture orientation on Windows, this will sort out the problem.
Oct 18, 2008 | Xerox XA7-172i 17" LCD Monitor
E-Machines T5048 (7136) PC Desktop Logo
152 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
