Question about GE Refrigerators
Ge zfsb23drh replaced board now only flashes 000
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Refer to tech to reprogram control it is usually be hind the toe plate on the left side cheers
Posted on Dec 13, 2013
Fault 16 light 00010 000
Your motor controller board is faulty and has no motor movement.
Mar 29, 2014 | Fisher Paykel Eco IWL16
Sta-rite sr333na not working at all. Intermittently flashing service heater and service system and 000 on screen
sounds like a bad board. if you remove the 4 screws holding the casing together (5/16 nutdriver) you can remove 2 cotter pins and flip the control board over. now look at the leds on the back of the board when then heater has tried to start. chances are, if you dont get any lights, youll need to replace the board. but then you may also notice mice may have nested in your heater and chewed your wires. get a good look at everything inside the heater.
Mar 09, 2014 | Sta Rite Pool & Spa
How do I test the main board?
Please contact the authorized service center for Dynex. Gopakumar Gopalan Google
Mar 02, 2014 | Dynex 756TXBCBZK05700 Main Board for...
Replaced electric board on as2628hekb now Get PE0 000 HELP
You have this posted in the wrong section, this is for car and truck problems.
Jun 13, 2012 | Cars & Trucks
PSS23SGSSS Front Door Controls not working
if you have replaced the mainboard in the rear of the unit,and it still doesn't change temps then you need to replace the interface control that your using trying to reset the temps
May 02, 2012 | GE Profile¿ Energy Star® 22.6...
The lights do not come on my LJ 1012. I have power coming to it (I substituted a LJ 1020), The power switch is on, and the one fuse inside near where the power comes in is good.
I you are tec guy:
Remove power supply board check secondary section power voltages, if not voltage, check primary section if found any component faulty replace it, if you are unable to repair it replace power supply board..
part no : RM1-0807-000, 110V
: RM1-0808-000, 220V
Sep 09, 2011 | HP LaserJet 1012 Printer
No display on temp controls and both frig and freezers are warm. i don't here the motor running at all. this happened after we had a power flash do to weather.
your main board in the back of the unit is bad and needs replacing,if you recently replaced a burned out light bulb in the freezer and now they strobe rapidly this is another good sign its this board the new board is a G.E. # WR55X10942
Aug 22, 2011 | GE PFS22SBSSS Stainless Steel French Door...
I have on element flx 2210 22inch lcd tv and when i power the tv to on the little blue light lites up for say 5 to 10 seconds then goes out and changes to amber without coming on and when looking down...
As others have stated your problem is most likely caused by bad capacitors on the power supply board. This power supply board is the 200-000-xxxxtltx and is the same board used in the Polaroid TLA-01911 TVs. Here is a repair guide that shows what capacitors to look for and replace on this board to rebuild it. This is much less than buying a new board even if you could find one for sale.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
Apr 22, 2011 | Element Electronics FLX-2210 22 in. LCD...
Codes for ge
Hello
Three digit universal remote codes for GE are:
000/ 003/ 004/ 009/ 022/ 031/ 044/ 052/ 054/ 055/ 087/ 092/ 103/ 107/ 125/ 164/ 181
Four digit universal remote code for GE are:
0031 0107 0164 0004 0009 0044 0054 0000 0342 0003 0125 0015 0022 0052 0087
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 17, 2011 | GE 27GT616 27" TV
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
