Question about Goodman GMS80904BNA Open Flame Mid-Size Heater
When i turn my heater on the flames arer going above the white plate and burning the metal above them ?
  • 148 Answers
It is sound like the heat exchanger is restricted
Posted on Feb 06, 2014
I HAVE A VENLESS HEATER GLO-WARM HEATER THAT THE FLAME IS SHOOTING ABOVE THE BRICKS AND HAS EXCESSIVE GAS FUMES APPEARS TO HAVE A LARGE FLAME WHAT CAN IT BE
can you turn flames down with the control knob ,if not you need control gas valve,that if burning right gas for heater you got. Check the data plate.If not right gas your heater your living very dangerous.
Jan 22, 2011 | Vanguard International Blue Flame - Large...
I have a monitor 2400 and it is flashing code E01 anyone got an clue what that means
E01 means the flame rod is sensing a flame when there shouldn\'t be one. This is caused by a grounded flame rod or pinched wire. For some reason the flame rod could be touching metal inside the heater. The flame rod could be bent or the burner ring is warped so much that it is touching the flame rod. Another possibility is the wire for the flame rod has somehow gotten pinched. If you remove the front cover and the black grill from the heater, you can see the window into the burner. The plate it is attached to has about 10 screws holding it on. You can remove the plate using caution not to damage the gasket and look into the burner to see what is going on. The flame rod should be centered between the burner ring and the burner. Let me know what you find. If you need to order parts I can help you with that.
Niten\'s Heater Service on Facebook
Jan 17, 2011 | Heating & Cooling
Why does my torpedo heater blow flames and will it eventually go away?
Your torpedo heater should be blowing the flames against a metal plate which gets red hot. This is how it works. In order to make the units safe, no CO, they need to get as much air as possible into the unit and allow the flame to burn with no restrictions. Yes it will probably do this as it is normal. Thanks for using FixYa. If you need more help let me know.
hardrocko
Feb 11, 2010 | Rival Heating & Cooling
Pilot flame burns above pilot tube in propane heater. the sensor does not register. the pilot top of the tube shoul glow red. I have cleaned the tube, in few occasions it has lit and worked for above 10 to...
Hi it there a leak on the pilot causing it to burn that high can you adjust the pilot gas going in to the pilot ?
have you cleaned the pilot injector out or is the hole in the injector too big
Jan 25, 2010 | Williams 2509612 Ceramic Mid-Size Heater
The plate do not turn red hot. the flame burns outside the plate
Sounds like it's getting too much fuel. Decrease the fuel pressure slightly and see what happens. pressure regulator looks like a pipe plug with a hole in it at rear of pump.
Jan 15, 2010 | Desa International Unvented Gas Space...
I have a Toyostove Lasr 73 which started complaining of an EE 2 (ignition failure) on startup just this morning. The fuel lifter seems to be working and I can smell a bit of kerosene in the heater, so I...
An EE 2 message can mean 2 things
Ignition never happened or unit did not sense flame
You should see the Igniter glow through the peep window during
pre-heat, easy er to see with front cover off.
If you do see a glow and flame happens, but unit still errors out.
Try to clean flame rod sensor.
Unplug unit.
Single white wire going to burner pot. (pull straight down)
2 screws hold a plate
Turn sensor to 3 o'clock or 9 o'clock position
pull sensor out easily
Clean sensor with sandpaper- down to shiny metal
Good Luck
Dec 14, 2009 | Rinnai Toyostove Direct Vent Heater:...
Gas heater won't ignite
I agree. Either the pilot flame is dirty and is not making good contact to heat up the bi metal strip on the pilot assembly, or the pilot assembly is defective. 90% of the time if you clean the pilot orfice and the pilot burner it will take care of the problem
Nov 16, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
100,000 btu all-pro kerosene heater
i have a 100 000btu/hr the ign. plug is bad wher in ga i can find one arer macon ga
Jan 22, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Burnt hole in metal plate inside microwave oven
Ok stop useing oven and unplug! THIS CAN BE FIXED!!! Go to a home improvment store and buy a small bottle of white liquid enamal....Clean up the area that is missing and flakeing and then apply the enamel over the hole and let dry overnight! now that the exposed metal is covered back up it is safe to use and will not spark or cause any more soot!
PLEASE rate my response to your question!
THANK YOU!
Jan 08, 2009 | Microwave Ovens
Propane Reddy Heater
AIR MIXTURE ADJUSTMENT IS CRITICAL ON ALL GAS BURNING HEATERS. SOUNDS LIKE YOU HAVE INSUFFICIANT CUMBUSTION AIR WHICH WILL CAUSE A WHITE AND LAZY FLAME .... FLAME SHOULD BE BRIGHT BLUE WITH NO WHITE OR YELLOW TIPS ON THE FLAME.
Apr 06, 2007 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
19 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
