Question about Lexmark Optra Lx+ Laser Printer
Printer Error Code: 941.00 SERVICE TRAY 1 FAILURE
Solve the plroblem in di 620
The 13xx - printer engine malfunctions
13F0 -400 dpi SOS sensor detection failure.
13F1 -600 dpi SOS detection failure.
13F2-universal tray adjustment failure maximum.
13F3-universal tray adjustment failure minimum
13F4-optical system out of adjustment
Dec 15, 2013 | Minolta DiALTA Di520 Laser Printer
Printer Error message : Printer Error has occurred. 6000
Error 6000 gets displayed when there is a paper jam or other general malfunction. When the message "6000 Printer error has occurred. Turn off the printer then back on again. If the problem persists, see the manual." Is displayed, something may block the paper feed tray from opening.
If the printer is surrounded with documents or when you copy large documents such as books, make sure that you secure the clear space in front of the tray before printing / copying. When the error message above is displayed and if you find something is in front of the tray, remove it. Then, turn OFF the printer and back ON again and the printer will be ready for printing.
If you still have the trouble, contact the repair service.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
Dec 21, 2010 | Canon Office Equipment & Supplies
I got a error code C-0204 and I`ve checked the tray 2 and is everything ok, but i still receiving this message and i cannot print. Please any help?
C0204 as I see you already know is a tray 2 elevator failure. Meaning the machine does not see tray 2 lifting up the paper. This is usually caused by improper paper loading, elevator sensor failure or lift motor failure. You can still use the copier/printer if you leave tray 2 open and inch or 2. Just use the other trays until repairs can be made.
Good Luck and Thank You for using Fixya.
Sep 25, 2010 | Konica Minolta bizhub C250 All-In-One...
A paper jam was not cleared in a timely manner, now the machine will only display "Error Code C0202, Call Technician" It is Saturday and I can not get a hold of anyone at our support center. How can I...
C0202= tray 1 elevator failure.
Open tray 1, check and make sure paper is loaded correctly.
With tray open, open and close front door. This will reset error code. With tray 1 open look to see if paper is stuck behind tray in back of machine, if so remove it ( this will block the lift motor for the tray).
Close tray 1, if you hear a popping noise the lift motor is damaged and will have to be replaced. Until it is replaced operate machine with tray 1 out to prevent error code.
Sep 18, 2010 | Konica Minolta Bizhub 362 Copier
I have a WorkCentre 5225 and it is telling me that I have an error (code #071-210) what is this error?
That error specifies a Tray 1 lift failure.
You probably can hear the motor lift 127K38171 when you re-insert the tray, so maybe the lift motor is bad or maybe a sensor
930W00113 is falsely accusing our motor.
Whit
Item, Inc
Aug 13, 2010 | Xerox Workcentre 5225 / Copier, With...
Error code C0202
this is a tray 1 lift up failure code pull the paper tray out and check to see if some torn paper is blocking the lift sensor look around where the paper is fed into the feed plates if not it could be a failed lift motor or sensor and they will need to be replaced
Nov 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
241.10 paper jam- couldn't find any paper jam. How do I clear the message?
Error Code: 241.10
Page was not properly picked from tray 1
Possible Causes
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Solutions
1. Fan media.
2. Turn media over.
3. Reduce amount of media loaded in tray 1
4. Replace pick tires.
Oct 29, 2009 | Lexmark T640 Laser Printer
Canon IR2018 E007
E007 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
you need to call a canon technician to sort it out
Mar 22, 2009 | Toshiba e-Studio162D Copier
913 service motor error
If this is the first time you have seen this error, do the following:
  1. Power off the printer.
  2. Remove all installed paper trays.
  3. Make sure the paper is loaded correctly in each tray. If it is not, reload the paper into that tray.
  4. Look up into the printer where the paper tray slides in and out. Check the feed (autocompensator) assembly for any damage.
  5. If everything is fine, reinstall the tray and power on the printer.
  6. Try printing a few print jobs.
  7. If the error does not return, continue using the printer as before. Keep an eye on it for the next few days. If the error does not return, it may have been an isolated incident.
  8. If the error returns just as soon as you power on the printer or when you try to print again, you will need to find out which paper tray/paper source is causing the problem.
  • If the printer has only the one integrated paper tray, the problem will be with either the tray 1 pick arm/autocompensator assembly or the printer's engine/system board.
  • If the printer has more than one paper tray installed, try printing from each paper tray one at a time. The best way to do this is to have all of the paper trays empty and then proceed as follows:
    1. Put paper in tray 1 only.
    2. Print from tray 1.
    3. If tray 1 works fine, empty tray 1 and put paper in tray 2 and so on until you encounter the error message.
    4. If you receive the error when printing from one particular tray, power off the printer to clear the error.
    5. Power the printer back on.
    6. Skip the faulty paper feed slot and move on to the next one (if another one is present). If you can print from all but one of the paper trays, this is the source of the problem.
      If you have extra paper trays/drawer units installed and the error occurs from only one particular source, there are some things you can do as a temporary fix.
      • If the error is occurring from an OPTIONAL paper drawer/source, power off the printer and remove the defective drawer from the printer. You will then need to set up the printer to print from a different tray. For information on removing an optional drawer, click here.
      • If the error is occurring from the integrated paper tray (tray 1) AND you have optional paper trays installed, take all of the paper out of tray 1 but leave tray 1 installed. Set up the printer to print from one of the other paper tray sources (tray 2, tray 3, multi-purpose feeder, etc.).
    7. And if your getting the same error then you need to get it serviced...
Sep 09, 2008 | Lexmark Optra SC 1275 Laser Printer
Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Mar 29, 2008 | Minolta bizhub 200 All-In-One Printer
Lexmark Optra Lx+ Laser Printer Logo
129 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
