Question about Toshiba Lands Phones
I want to change the name at the top left of my LCD display. My phone is a Toshiba DP5122-SD and that person no longer works here.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
This is accomplished easier if you contact the company who put your system in to program this. You can also check the users guides at
Posted on Dec 31, 2013
  • 201 Answers
SOURCE: panasonic kx-t7639
This would be programmed in the phone system, not the phone.
Posted on Sep 25, 2007
mdesmet
SOURCE: Change name display on Toshiba DKT2020-SD
I am assuming you want to change the display to read another persons name, or blank. If that is correct:
Press a [DN](labeled intercom on my system) + #621.
That opens edit mode.
an example. My phone reads "MARK 29"
where Mark is the user, 29 the extension. John replaced
Mark, so target is "JOHN 29"
so intercom # 6 2 1 puts me in edit mode
# toggles between alpha/numeric
* moves the cursor, I repeat * until cursor is under M
Hit the 5 key, changes the M to J and moves cursor under the A.
Hit the 6 key, the A changes to M, and the cursor moves to under the R. I hit 0 which changes the M to N. I hit 0 again, the N changes to O.
Hit the 4 key, the R changes to G. Hit 0, G changes to H.
Hit the 6 key, K changes to M. Hit 0, that changes the K to M. Hit 0, M changes to N.
We are done, as the extension number stays the same. Hit spkr key to leave edit mode.
Hope that helps!
# toggles alpha/numeric
Posted on Dec 10, 2007
SOURCE: How do I change the name on my Samsung Prostar DCS 24B phone?
To Program an extension name:
1 Press the TRSF key and dial 104
2 Enter the name using the dial keypad like you are texting
When the next character you want appears on the same key press the volume UP key to move the cursor on space to the right.
To make any changes press the volume DOWN key to move the cursor to the left .
If you want lower case letters press the A key brfore entering letters.
3 Press the TRSF key to store the name
HTH
Jo
Posted on Dec 18, 2008
cnavarro
  • 2460 Answers
SOURCE: change name that comes up on display phoned
Name programming requires access to system programming. If you go to the main phone and, without picking up the handset, press PROG and dial **1234 and ENTER, it will go into programming mode. Dial 004 and you are looking at the Ext Name screen. An ENTER at this point starts at 101 OPERATOR (default). Now just start pressing the letter keys and the right arrow to spell out the names. The keys press 7 times for ABCabc2. Punctuation and special characters are under the 1 and 0 keys and STORE or ENTER saves your work.
When I install my systems, I let everybody have access to the programming by class of service. You may be able to program from any phone in your system, it depends on the installer. The phone that rings when you dial "0" is probably the main phone if you can't program this from your own phone.
PROG exits programming.
Carl
Posted on Mar 18, 2009
Press "intercom" button, then #621. Use * to move the cursor all the way to the left. Use the # sign to change from numbers to Alpha. For example: You want "N", but the "M" comes up. Press the "0" to toggle to additional letters on same number key. For a SPACE, use the number 1 and toggle to get a space.
Posted on Feb 01, 2010
CHANGE THE DISPLAY NAME ON MY TOSHIBA DKT3210-SD PHONE
On a CiX or CTX, it's handled via the System Administration Program or Personal Programming Interface.
Sep 09, 2014 | Toshiba DKT3210SD - - Phone
How do i change the name on the lcd display
IN THE IDIOTS GUIDE YOU WILL FIND A RESET BUTTON AND CHANGE OF DISPLAY, NORMALLY ON THEM THERE SHOULD BE A BUTTON YOU HOLD FOR ABOUT 5 SECS
Dec 26, 2013 | Toshiba DKT-3220-SD Corded Phone
Nov 04, 2009 | Toshiba DKT-2020 Corded Phone
Where is the Program button on the DKT3220-SD ?
press intercom #9876 HOLD, flexible buttoon pressed to assign, press the bitton code, press again the bitton to set DND = 180 short key for extn 610+extn number to change display name must set at administrator phone usually is receptionist phhone
Mar 17, 2009 | Toshiba DKT3020SD Corded Phone
Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Mar 11, 2009 | Toshiba DKT3020SD Corded Phone
We have a Toshiba DKT 3210-SD phone system and can't seem to figure out how to reprogram the name of the person that is using that phone, The names located in the top left hand corner of the screen are of...
If you have the software you can get in and program via station assignment.
If you admin, programmed on any ext you can program.
If not we can remote into your system and change them.
info@ameritelnj.com
Tony
Jan 26, 2009 | Toshiba DKT-2020-SD telephone
I NEED TO CHANGE THE NAME ON THE WINDOW OF THE PHONE
wat system using?
find out the adminstrator phone (pic to set the speed dial)
must hv displayed phone.
press MODE will see PHONE NAME press HOLD display show ID DN it means key in extention number, after that key in name, press HOLD to confirm, repeat step for other extention name
press MODE untill time appear
Jan 20, 2009 | Toshiba DKT-3220-SD Corded Phone
Your Toshiba Name Change question of Apr 2008
Maybe I can help, Press ( DN ) + #621
Display changes to USER NAME ?
Enter new name
Press SPKR
1 - moves right
* - moves left
# - toggles between alpha mode / numeric mode
0 - scrolls the alpha / special characters
To blank out any portion of name press 1 ( in alpha mode ) and move cursor to thr right
Good Luck
Aug 05, 2008 | Toshiba DKT-2020 Corded Phone
Hope that helps!
Dec 10, 2007 | Toshiba DKT-2020 Corded Phone
Lands Phones Logo
235 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
