FixYa.com
Tags:
Ricoh Aficio CL1000N Printer
Ricoh fuser unit
posted by aandrei on Oct 10, 2007
looking for fuser unit for ricoh cl800 - i believe it is compatible with cl1000n?  also compatible with brother printers partnumber fp4cl...is this true...what about voltage, is it set on machine or is the fuser unit iself "volted" as secific, like 110V or 220V...your feedback/help is dearly appreciated.
Thanks - Andre
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 02, 2008
Not Rated (0)
drichards
Rank:Guru Guru
Rating: 87%, 60 votes
The machine's power supply will determine the voltage. The part number with NA is 120v and the other EU is 220v. If you are running from a 120v outlet, get the 120v version.
I highly doubt if it is compitable with the Brother printer.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Printers problems?
Printers
rtl not found cannot print
When I give something for... Answer This...
Printers
need to install all in
need to install all in one... Answer This...
sc 310
how can i resolve an sc310 on a... Answer This...
ricoh cl1000n error
CL1000N when turned on has... Answer This...
Printer prints small lines...
My printer prints small lines... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
