Question about Sony Handycam CCD-TRV318 Camcorder
How to use pinnacle 14 studio with sony cam tvr-318
Exactly what wires do I need to import video from my cam to pinnacle dazzle video creator plus HD --
    Problem Solver:
  • 6 Answers
You will need to have an i-Link cable, also known as a IEEE 1394 cable, which is a four pin to four pin cable. That will hooked to the DV output from your camera to the DV input on your computer, if so equipped. Also there is a cable with a four pin i-Link to USB cable which I use my self on my system to import DV from my camera to the edit program.
Hope that this is helpful to you.
Posted on Nov 28, 2013
5 Suggested Answers
leorcid
  • 281 Answers
SOURCE: On my Sony HandyCam, I tried to import HD Video I
Which model your handycam is? Are you using one with Flash card or is it minidv? If it's flash card you can try using a card reader, and if it's a minidv, you should use a capture card to transfer the video.
Posted on Dec 23, 2009
LongPockets
  • 1177 Answers
SOURCE: How do I import video
You don't. According to Sony, your camera will not stream video via the USB port. You can only do this using the i.Link connection (what everyone but Sony calls Firewire). The list of camera models that will stream via USB, and the method to do it, is on THIS LINK Your camera is not in the list.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. Or maybe you have a Mac. You haven't said.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select your operating system, then Mini-DV as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
Posted on Jan 03, 2011
  • 269 Answers
SOURCE: while capturing video from sony
Sounds like time code breaks.
If you stripe the tape (record in one continuous run with the lens cap on and audio off) this will assist greatly.
Posted on Feb 17, 2011
theJayGuy
  • 4 Answers
SOURCE: I purchased a Pinnacle Dazzle
Sony DCR-HC38E should have an interface called 1394, or the firewire. so you need to use a FireWire cable to connect it to your computer's firewire interface, some laptops have it built-in, If you don't have one on your computer, you can either purchase a IEEE1394/FireWire adapter, which should be under 100 or even $50.
Connector Type1.0 x Composite video/audio output , 1.0 x S-Video output , 1.0 x USB , IEEE 1394 (FireWire/i.LINK)
Posted on Sep 09, 2011
Dazzle DVD recorder software does not save my video properly
You don't say where you are trying to save it to. Try saving it to the default location on you desktop hard drive and then transfer it to your phone.
Sep 15, 2012 | Pinnacle Dazzle DVD Recorder
How do I download my DV tapes from DCR - HC19E sony to my Dell window 7 os lap-top please. I've lost the original software.
Hi, I'd suggest getting a Pinnacle Dazzle, it comes with a part that the connection's from the camcorder plug into then it plugs into your USB and it comes with software for transferring the video as well as doing basic editing. You can have a look at it here: http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Dazzle/Dazzle+Video+Archiving/Dazzle+Video+Creator+Plus+HD.htm
May 13, 2011 | Sony DCR-HC19E Mini DV Digital Camcorder
I just purchased an Dazzle HD.. and it came with pinnacle studio 14, I downloaded pinnacle and i have the dazzle hooked up right and where it is supposed to show my screen it just has the pinnacle studio...
It requires at least  DirectX® 9 or 10 compatible graphics card with 64 MB (128 MB or higher recommended) to run and if it doesn't meet the requirement s it wont have the support it needs to run. Check this website against your computers specs.  http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Dazzle/Dazzle+Video+Archiving/Dazzle+Video+Creator+Plus+HD.htm
May 04, 2011 | Cameras
I installed pinnacle 14 hd studio in my son's computer. It worked just fine. It came with a video converter called dazzle. I installed a Radeon HD 5670 graphics card in the computer and now studio 14...
I had the exact same problem when I installed my Radeon 5670. I fixed it by going to device manager, video adapters, update driver (let it search the web and install). Worked fine after that. Good luck!
Jan 26, 2011 | Gateway Computers & Internet
I have Pinnacle Studio HD 14 and it comes with a tool called AMCAP which allows you to record footage off a video game console through a capture card. My capture card is Dazzle Video Creator platinum...
hello, my name is Adam, i am going to try and solve your problem, to do this all you need to do is start recording with your dazzle through pinnacle studio, then open up amcap, here I might be a little sketchy as I do not have the best memory, but at the top I think it sais something like capture, click on that, then at the bottom it should say like options or something, then when you click on that there should be a little drop down menu with different things such as NTSC and Secam, you want to choose the one saying Secam_B, once you have done that minimize amcap and then you should be recording in colour in pinnacle studio. Although you have to do this everytime you start recording which is the down side, need any more help? send me a message on msn, my msn is captain_night195@hotmail.co.uk
Sep 07, 2010 | Pinnacle Dazzle Video Creator Platinum...
How can I import my videos from my Hi8 video camera to the Dazzle Plus Pinnacle 12
Welcome to fixyah,
Open your Studio 12 and then click on capture tab and then go ahead and click on setup capture source under video click and choose your dazzle device. Connect your yellow red and white cable to your dazzle and then end part to your HI 8 camcorder. Open your camcorder and when the video showing to your preview windows of Studio 12 then hit start capture
Jul 30, 2010 | Pinnacle Dazzle DVD Recorder
My cam is always get dark
Get the results you need, where you need them, when you need them. Red 3GL is a powerful new version ... ADS USBX-2040 Turbo USB 2.0 WebCam with USB 2 PCI Card ADS XGA128 TV Elite XGA ..... Pinnacle Systems 210100316 Dazzle Digital Video Creator 80. Pinnacle Systems 210100325 Dazzle DM21600 usb2.0 ...
www.9to5computer.com/.../Video-Editing-and-Production-Equipment-Index.htm
Jul 19, 2010 | Zio 210100325, DAZZLE DIGITAL VIDEO...
Sony Handycam CCD-TRV318 Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
