Question about Briggs & Statton Briggs & Stratton Electric Starter 12.5 16 693551 New 33-772
Remove and replace starter on 303447
Remove and replace starter on briggs &Stratton model 303447
How to remove starter on briggs stratton model 294777 v-twin motor
You may have to remove the flywheel to gain access to the starter bolts !
Sep 27, 2014 | Briggs & Stratton Garden
I have a B & S Mod. # 303447-1042-E1 that won't turn over with the electric ignition switch.
A bad Starter Solenoid (Heavy Duty Relay). You can locate it by following the cable on the starter to it. It also should have a cable going from the battery to it, and a small wire from the ignition switch which activates it. Its purpose is to act as a high current switch between the battery and the starter.
Apr 15, 2014 | Briggs & Stratton Tools & Hardware -...
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
Removal of carburator from model 303447-0446-01 engine
How can I remove the drive shift pulley on a18hp Briggs & stratton engine
Feb 05, 2014 | Briggs & Stratton Briggs Stratton Intek V...
B&S Model: 303447-1078-31 16hp stops running after warm-up
bad coil it will seem like a fuel issue and the spark will look fine threw the spark plug but with a real spark tester you will see it is a yellow spark instead of blue replace coil and thank me
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Replace starter on my 20 hp briggs
check that battery is installed properly,i once got a bad batterie that was wired reverse.and the starter ran in reverse.
Mar 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Statton Briggs & Stratton Electric Starter 12.5 16 693551 New 33-772 Logo
50 people viewed this question
Top Briggs & Statton Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Briggs & Statton Tool and Hardware - Other Expert? Answer questions, earn points and help others
