Question about Whirlpool LER4634J Electric Dryer
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Whirlpool AWZ 410 is not generating any hot air. The drum is tumbling but with cool air only & hence no clothes drying
    Scholar:
    New Friend:
  • 81 Answers
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Posted on Nov 27, 2013
  • 3 Answers
SOURCE: Whirlpool AWZ 3303 Tumble Dryer
You can usually download from Whirlpool website
Posted on Jul 10, 2008
ginko
  • 19396 Answers
SOURCE: condenser dryer not getting clothes dry
There must be one or two circuit breakers, usually at the back of the dryer, check them out.
If this does not fix the problem, then possible faults are the thermistor or the heating element.
Most likely you will need to have the heating element replaced.
If you decide to call a technician you can use the phone number listed on the owner manual.
You can find parts and diagrams here.
See also this website, the also sell parts and have some schematic: What is wrong with your Dryer?
Posted on Nov 05, 2008
  • 291 Answers
SOURCE: wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Posted on Dec 30, 2009
  • 177 Answers
SOURCE: dryer not getting hot enough to dry clothes
First check the power coming in, you need 240 volts. 120 to neutral on both sides and 240 across both. If you are not comfortable with a VOM volt ohm meter call somebody who is.
Be aware when every you remove a panel you will be exposed to sharp surfaces. Unplug first and be careful!
Whirlpool dryers have a thermal fuse inside the back of the dryer, if this is open the dryer will not heat. You will need to check this with a meter it should be closed. A quick and dirty way to check it, remove it and wire it in a circuit with like a flashlite or radio. the flashlite or radio should work, this is a dirty way to check fuses if you dont have a meter.
While you have the dryer open, vacuum it out and clean the venting.
Please repost if you have more questions
  • 77 Answers
SOURCE: Whirlpool AWZ-7813 won't dry - no heat
it will either be you element or the thermostats that have failed.
Posted on Mar 20, 2010
Cannot remove rubber door/drum seal on whirlpool 1000 awz 410
I also need to replace the door seal on my Whirlpool AWZ 410 washer. Does anybody have detailed instructions of how to do this for this particular machine model (not generic instructions) & know if it is necessary to remove the front panel on this machine in order to remove the existing seal please?
Feb 23, 2013 | Washing Machines
WHIRLPOOL AWZ 410-1000 parts
I bought before through Ebay , might get it cheaper there though .
Just make sure you got the right part number :) and search it ..
Regards,
Feb 19, 2013 | Whirlpool AWZ410 Front Load Washer/Dryer
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
Whirlpool LER4634J Electric Dryer Logo
493 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
