Question about Lexmark X1270 All-In-One InkJet Printer
Encoder strip Hi there! Does someone know how I can attach back a encoder strip that came out from my lexmark all-in-one printer X1200 series? Thanks in advance!
aomcopier
  • 22 Answers
SOURCE: Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Posted on Apr 01, 2007
SOURCE: cannot install
I don't know what you mean that it is not available. I assume that you are simply trying to select an available printer on Windows?
You'll need to download and install the driver here. Just select your OS:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Please rate me :)
Posted on Apr 26, 2009
Roop1980
  • 228 Answers
SOURCE: MY Lexmark X5150 All-In-One InkJet Printer displays the message: HARDWARE ERROR 0502
Unfortunately this appears to be a hardware failure and the printer is out of warranty. It is likely that the parts, repair and replacement fees would be more expensive than the actual cost of a new printer at this point.
Posted on May 11, 2009
nourahm
SOURCE: Replacing encoder strip om Lexmark X6170
First unplug your printer...
Lift your printer top, like you are going to change your ink cartridges.
Unplug your scanner & control panel by disconnecting the 3 ribbon cables
Then, you will need a screwdriver (philips head). remove the screws (about 4) from the inside housing cover.
After you have this cover off...
You should be able to see the sides of the cartridge. Take your encoder strip (gently) and thread it through the back of the cartriidges. Note: There are small slits on the side where you can thread.
If the encoder strip has come completely off (there should be tension if it is connected), you will have to located the right and left "pins" to attach it back to. I have a lexmark x-2500 so, mine are on the metal frame. The right end (arrow up) attaches to a metal strip which points straight towards you (a part of the metal frame) with a small notch at the right end and on the left end there's a type of "punchout" pin which is a part of the metal frame. I had to slightly bend the right end pin to the right, just enough to create some tension & keep the encoder strip from popping back off. The left end pin should already be bent out to the left.
Hopefully, this helps someone
Posted on Jun 05, 2009
SOURCE: LEXMARK X6170 HARDWARE ERROR 0502
The problem is you can't see the slot, as it's in back of the carrier. I took a dental mirror that has a built-in light on it and found the slot. Without that it's impossible to see, and you'll just have to follow the directions by feel.
Posted on Dec 10, 2009
My encoder strip is dislodged for my lexmark4650 printer...how can I attach it again? Thanks
Hi Kim
Please get the information from this link you will get the idea
http://support.lexmark.com/index?page=content&productCode=LEXMARK_X7675&segment=SUPPORT&viewlocale=en_US&searchid=1262004228106&actp=search&userlocale=EN_US&id=SO4927
Regards
Jul 16, 2011 | Lexmark X4650 InkJet Printer
My Lexmark 4 in 1 X5630 printer is saying carrier jam. How do I go about sorting this out?
I got an amazing solution to this problem that worked for me.......my printer is working now :)
just sharing with you............
"Someone tried for hours to reattach my encoder strip, and finally figured out the way to do it after reading many web postings, and my own trial and error. The key is to use a "dental mirror" that you can pick up at a pharmacy or hardware store for about $5. (Perhaps a small compact mirror may also work.) And you need to focus light back there. (I used a head lamp.) The problem is you just can not see the small slot through which the encoder strip must be threaded from the front of the printer. It sits in back of the ink cartridges. This thin slot "tunnel" goes though a rectangular piece of plastic. You can feel the rectangular piece of plastic in back of the ink cartridges, and looking with the dental mirror you can see how small the slots are on the right and left side, through which the encoder strip must be threaded. After "seeing" these small slots using the dental mirror, you then can feel them with the tip of a fingernail, and know exactly what you are aiming for as you then feed the encoder strip through. (It doesn't make any difference of you feed the strip from the left or the right, but the down arrow end of the encoder stip must end up on the right when you later attach it to the wire tab.) I fed the strip "blind" after I had formed a strong mental image of exacly what I was trying to do, and now being able to feel the small slot I was aiming for with the tip of a fingernail. (It is tough working in the small space in back of the ink cartridges, and if you have really big hands and fingers it may be impossible. I did not want to use forceps or tweezers because of a fear of damaging the encoder strip.) The encoder strip then must be attached with the down arrow end on the right attaching to a flimsy looking wire on the right side of the printer. The left end of the encoder strip must be attached to a metal tab on the left side of the printer. You will need to hold tension on the encoder strip, and manually push the sliding ink cartridge back and forth out of the way as you attatch both ends. (It's probably a good idea to gently clean the encoder stip of all your fingerprints and any smudged ink with a tissue after you get it back in place. Also be sure to clean the metal bar the ink cartridges slide back and forth on, so you don't get error message 0502.) Be prepared for this to be a very frustating experience! You will be maddened by how many times it will take to thread the encoder strip though the slot, how difficult it will be to catch the end of the encoder strip on the wire and metal tabs, and how you will have to figure out how to hold tension on the encoder strip so one end won't fall off as you attach the other end. But once you use the dental mirror to see where you have to thread the encoder strip, and once you see the wire and metal tabs to which the ends of the encoder strip must be attached, then YOU CAN DO IT! It just takes persistance."
Jul 09, 2010 | Lexmark X5470 All-In-One InkJet Printer
How to install printer ?
Just go to Control Panel...........
Printers Folder...........
There u will see a Chk mark on Lexmark Fax X1240........
And u will see another icon which says Lexmark X1200 Series just right click on Lexmark X1200 Series not the Fax and Click on Set As Default Printer...............
After u do this U can go ahead Print............
Good Luck
Feb 16, 2009 | Lexmark X1240 All-In-One InkJet Printer
Feb 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
Hardware error 0502
The encoder strip may have gone out of range of the sensor, or it might be dirty.
  1. Switch off the printer using the power button.
  2. Disconnect the power cable from the back of the Lexmark X5100/X6100 Series.
  3. Leave the power cable disconnected for 30 seconds.
  4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
  5. Take out both cartridges.
  6. Place an index finger on the encoder strip on either side of the cartridge carrier.
  7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
  8. Lightly press the strip first to the rear and then forward, if necessary.
  9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
  10. Reconnect the power cable and switch the printer on again.
  11. Try to print....
Good luck...
Dec 15, 2008 | Lexmark X6170 All-In-One InkJet Printer
Hardware error code 0502
Hardware Error 0502 on LCD Display
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 09, 2008 | Lexmark X5150 All-In-One InkJet Printer
When trying to print either from a copy or the computer, printing stops midway and shows that an Hardware Error 0502. What is going on? Changed cartridges and reintalled the printer twice. What to do?
  2. Disconnect the power cable from the back of the Lexmark printer Series.
  9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer..
Dec 06, 2008 | Lexmark Office Equipment & Supplies
Cant receive a fax
HI try this its from the lexmark web site
Hardware Error 0502 on LCD Display ID:ENUS16536
Nov 21, 2008 | Lexmark X6170 All-In-One InkJet Printer
Hardware error message 0502 shows up on the display. What does this mean?
Cause
Resolution
You need to check the encoder strip on the printer. This is a clear strip running the length of the printer, above or behind the cartridge carrier.
    The red arrow points to the encoder strip. Click here
  7. for an enlarged view.
  8. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
  9. Lightly press the strip first to the rear and then forward, if necessary.
  10. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
    Click here for an enlarged view. The contacts on the back of the cartridge carrier are the ones to clean. Use a dry tissue.
  11. Reconnect the power cable and switch the printer on again.
  12. Perform the hardware test first without cartridges and then with both cartridges. Click on the applicable document below. How to Perform the Hardware Test on the Lexmark X5150
    How to Perform the Hardware Test on the Lexmark X6150/X6170
  13. Make a standalone copy.
  14. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Sep 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
HI try this its from the lexmark web site.
How to Perform the Hardware Test on the Lexmark X5150 ID:ENUS3744
Using the operator panel on the printer:
1. Press the Option button 10 times until Cartridges appears on the LED display.
2. Press the + button 4 times until Self test appears on the LED Display.
3. Press Select. The printer should print a sheet of paper with one black bar and one grey bar.
4. If the printer fails to print, remove both cartridges and try the test again. (It will feed the paper through and print a blank page.)
5. If the test works with no cartridges in the printer, run it again with one cartridge at a time installed.
Aug 21, 2008 | Lexmark Office Equipment & Supplies
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
