My tuuva will not power on
I try to power on but get an exclamation mark on the battery symbol
  • 5 Answers
SOURCE: Lexmark Printer - symbols
There's some error. Is this the only light that lit?
Posted on Mar 31, 2009
  • 11 Answers
SOURCE: light on. Exclamation mark within a triangle. Printing fine and clear. What does tis symbol mean?
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
Posted on Aug 17, 2009
  • 491 Answers
SOURCE: symbol with exclamation mark in a triangle keeps
How often does it appear?
Is it after the TV has been on for at least 10 mins?
It could be overheating.
Add a fan to get air flow into the set through a vent in the back....and see if that helps to keep the light off.
If this cures it....the internal cooling fan may have stopped.
Posted on Sep 06, 2009
SOURCE: the symbol is a yellow exclamation mark inside a
It is the Tire Pressure Mounted System (TPMS). It monitors the air pressure in your tires. If it is on, you have low tire pressure...or like me, it's just a faulty indicator. Mine came on, but I don't even have TPMS on my vehicle.
Posted on Oct 13, 2009
TDISLine
  • 1874 Answers
SOURCE: i have a yellow triangle with an exclamation mark
ESP = Electronic Stability Program malfunction indicator lamp (MIL)
1. You can try to disconnect the battery from car terminals, waiting for 30 minutes and connect again the cables in order to reset the ESP Electronic Control Unit (ECU).
2. If this procedure does not work you must use a diagnostic equipment connected to the Data Link Connector (DLC) of the car. The ESP ECU fault memory can only be accessed and erased using diagnostic equipment connected to the DLC.
Note: ESP function includes ABS (Antilock Braking System) function!
Posted on Mar 31, 2010
How Do i Fix My i Tunes Music ~~~~ They All Have An Explanation { ! } Mark On Them..???????????
Are you sure it is not a cloud symbol and arrow? That means they are being played from iCloud and are not downloaded to the device.
In your case however, you have deleted them or moved them.
If you see an exclamation point next to your items in iTunes
How to get rid of exclamation marks in iTunes, and get your music to play
www.macworld.co.uk/.../how-get-rid-of-exclamation-marks-in-itunes-music-play-360...Mar 3, 2015 - How to locate missing iTunes music and fix the exclamation mark problem in iTunes. ... How do I get rid of the exclamation mark and play my iTunes music again? ... Typically you'll find them in Home/Music/iTunes, but you might need to ... should be able to play all the tracks from that iTunes music library.
Tunes Music Have An Exclamation Mark On Them Google Search
Jul 17, 2017 | Audio Players & Recorders
What does the symbol !! mean at the end of a sentence
The exclamation mark (British English and Commonwealth English) or exclamation point (American English) is a punctuation mark usually used after an interjection or exclamation to indicate strong feelings or high volume (shouting), and often marks the end of a sentence. Example: "Watch out!" Similarly, a bare exclamation mark (with nothing before or after) is often used in warning signs.
Nov 26, 2016 | Cars & Trucks
What is the exclamation mark on the dashboard mean?
a tire is low on air the low tire light will go out reset when air pressure is brought up to match the other tires
Sep 15, 2015 | 2007 Toyota Prius
Exclamation mark is lite up on my dash of my 2010 honda accord
this can mean a few things depending on if there is a circle around it or if any other symbol is on, if you only have a exclamation symbol then it means you have a low tire check the tire pressures , good day
Sep 30, 2012 | 2010 Honda Accord 2.4
What does the (!) symbol mean on the dash? I looked in manual but just says tire issue? I have a 2010 Corolla
It is a sign of exclamation.
An exclamation mark, exclamation point, shout pole, or bang (!) is a punctuation mark usually used after an interjection or exclamation to indicate strong feelings or high volume, and often marks the end of a sentence.
Dec 15, 2010 | Microsoft Office 2010
The light came up on instrument panel. its the one looks like an exclamation mark. is ther a problem with the hydraulic brake system?
There are two symbols with an exclamation mark. The first is a oblong circle with the exclamation mark inside with ( ) on each side of the oblong circle. That symbol is for brake system warning light. Check brake fluid level, check brake pads. The other symbol is (!) and is flat on the bottom its suppose to resemble a tire, it means there is a problem with the tire monitor system, check your tire pressure, if you have low tires you will have to drive car after servicing the tires then the light should go out. Tire pressure should be on a placard on the driver door or door frame.
Oct 05, 2010 | 2008 Saturn VUE
I have a yellow triangle with an exclamation mark
Mar 31, 2010 | 2002 Audi A4
Orange light with exclamation mark
That symbol is the Low TIre Pressure Warning. It tells you that your tire pressures are low.
Aug 31, 2009 | 2001 Toyota Prius
The symbol is a yellow exclamation mark inside a
Aug 26, 2009 | 2004 Dodge Durango
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
