Question about Amana AGR5844VDS
Oven won't light
The oven will not light. The burners and broiler work fine. Smell gas when I try to start the oven.
SOURCE: Amana ARG7300w oven inop
It has a bad oven igniter.
Posted on Aug 27, 2007
SOURCE: Broiler not workig
The flame maybe not enough try to clean the gas nozzle at back potion of the oven , look for small wire to clean the clug by dust and rust , after cleaning test the flame , the burner will increase in flame .
Posted on Dec 25, 2007
  • 20 Answers
SOURCE: Oven will not light
If its a gas range, If there is a broiler tray under the main oven, the place to lite the oven pilot light is at the top of the broiler box, use a flash light to look in at the top, to see if theirs a place to light a pilot light.
Posted on Feb 06, 2008
SOURCE: Amana Model ARGS7650E Oven Problem
No matter that the igniter glows you must measure the current... If the current is less than 3.2 or 3.6 you must change it (this current is for the igniters with rectangular white base).The current to open the valve is the same that passed through the igniter so if it doesn't reach the proper value it will never open (or sometimes open sometimes not).Mine is not opening and the current is 2.9 so I'm going to replace it tomorrow.
Posted on Dec 26, 2008
  • 126 Answers
SOURCE: amana agr5735qds oven will not
There are two igniters in your oven one for bake and one for broil. The bake igniter very likely needs to be replaced. Igniter part number is 70080764.
Posted on Jan 02, 2009
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
My gas oven is not working-just used this afternoon for bread and chicken-it was fine-broiler and burners work ok
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 29, 2010 | GE Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Frigidaire gas range oven won't come on
the oven ignitor needs replacing, this is the part that makes everything works, it's a glow coil in side the oven, nest to the burner, that is the electronic pilot, when it goes bad the safety valve, the one that sends gas to the oven will not open to light the oven burner.
Dec 07, 2008 | Kitchen Ranges
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Amana AGR5844VDS Logo
74 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
