Question about Sewing Machines
BROTHER ULT2003D CARD READER WILL NOT READ CARD
Information on brother ult2003d machines
"So Long" means to increase the number of stitches.
Not filling in I'm assuming means you are missing stitches. Check underneath the fabric to see if the top stitch can be seen.
"No" will mean to increase the bobbin tension. The top tension should be on about four. This is the same bobbin tension that you are aiming for.
Oct 02, 2016 | Brother Sewing Machines
Not regonizing embrodiery frame
the problem could be the computer or a sensor, the machine may need to be serviced
Apr 28, 2016 | Brother ULT2003D Disney Sewing &...
Brother ULT2003D Plz say filter over screen can b replaced.Any idea on cost. Not sure if mom wiped with solvent but resp 2 touch, just can't see. Thanx 4 any help. Repair agt tryng sell me a new one.
the only suggestion I have is go or call a sewing machine shop that works on brother sewing machines and ask them about the screen,, and what it would cost to replace it, and that will help you decide if you want the repair cost or to trade it in on a new one,, BUT DON'T CALL THE ONE THAT WANT'S TO SELL YOU A NEW ONE...
Jun 06, 2015 | Brother ULT2003D Disney Sewing &...
Brother ULT2003D screen rubbed out. Resp to touch n I can sew. Can plastic face over lcd screen b replaced? Spk 2 a registrd repair agt says it's not worth repair n busy tryna sell me new 1.Thanx
You may be able to clear it up with a headlight resurfacing kit. These have some very fine sandpaper, rubbing compound, and a sealant. Low cost, and if it doesn't work, you are not out a lot.
Jun 06, 2015 | Brother Sewing Machines
MY MACHINE NOT READING THE CARD
If card is damaged replace it. Will it read other cards. Can you transfer info to another readable card. Call Brother Online.
Nov 09, 2014 | Brother Disney PE-180D Computerized Sewing...
Brother pacesetter ULT2003D
try using a different spool of thead on the top and bobbin
also try changing the needle
and if these suggestions don't help then call the repair shop and check
with them about the machine not sewing light fabric
Jan 04, 2013 | Brother PE770 Computerized Sewing Machine
Brother PE-150 cannot read PED card
there could be something wrong with the card or the card reader
could be going out.
you might check with brother and see if there is up date for the machine
that you can download.
also if the problem persists, the machine may need to be checked
Dec 14, 2012 | Brother PE-150V Computerized Sewing...
I have the Brother ULT2003D the part that holds the needle broke. When I tryed tightening the screw to holed the needle the part where the screw goes in broke. Where can I get a replacement?
Contact your local Brother dealer and ask the OWNER if the service tech can get one of these for you.
You should be able to pick it up without taking the machine in.
Mar 01, 2010 | Brother Sewing Machines
I HAVE A BROTHER ULT2003D SEWING/EMBRODERY MACHINE IT CAME WITH NO MANNUAL IM ABOUT TO EMB. A 100% POLYESTER SHIRT AND DONT NO WHAT TENTION TO SET IT ON THANK YOU C.C.
I would try embroidering on a scrap of like material to get the tension you want. My Brother (different model) manual doesn't say any specific tension setting for embroidering but just says to set the tension right for the fabric to be worked. If the fabric is stretchy, I suggest using a little looser tension than say cotton, just make sure it doesn't pucker the fabric.
Nov 19, 2009 | Brother Sewing Machines
Blank Card, PE Design says it's a ''read only''
Hi - I think the problem is that although the Magic Card is compatible with your machine, it is not recognized by with the PED writer. I have the Brother PED-Basic sfotware and a Brother PED-Basic USB card writer box. The only blank card that the my Brother reader can read is the blank cards made by Brother. Which embroidery machine do you have (not critical - I'm just curious).
If you have both a Magic card and Magic Box, the box should have it's own software. I don't think the PE Design software recognizes non-brother equipment (bummer). The link I've provided below is to a dealer that sells two different blank Brother Cards. One of the cards is 1 mb. The other is 4 mb. They are the same price. You might check your documentation to see whether both cards are compatible with your reader and software. If you're not sure, you can call the dealer directly and ask. I have dealt with this dealer many times and find that they have great prices and are very knowledgeable. This link should take you to the page on which the blank Brother Cards are displayed - scroll down if you don't see them right away.
http://webstore.quiltropolis.net/stores_app/Browse_dept_items.asp?Shopper_id=1617251646531617&Store_id=492&Page_id=17&categ_id=42&parent_ids=0,20
This dealer is located on the East Coast, so you probably won't be able to reach them by phone until tomorrow. I don't know of a dealer on the West Coast to whom I can refer you. One more thought - Babylock equipment is often interchangeable with Brother equipment. If you have a Babylock dealer in your area, you might be able to find a blank Babylock card that you can buy off the shelf. Just make sure you can return it just in case it won't work.
Let me know if I understand your situation correctly - if not, send me another comment and I'll be happy to research further. BTW - if it turns out that you can't use the Magic card and can't return it, you can probably sell it online.
Thanks for getting back - I really love doing this. If you have general questions about embroidery, feel free to ask. I own several consumer embroidery machines, and I operated a commerical embroidery business for several years.
Ginny
Feb 05, 2009 | Brother Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
