Question about Vizio E470VA 47 1080p 120Hz LCD HDTV
Speakers are blown
Is replacing the speakers something one can do on their own?
    Top Expert:
  • Vizio Master
  • 74,377 Answers
If you are sound in electronics to an extent, you can do it by yourself.
To get more details, http://electronicshelponline.blogspot.com/
Posted on Nov 27, 2013
Very low volume on all inputs
first thing,,,,make sure the speaker wires are not touching each other.
i dont think it would be a fuse because that would cut the sound completely.you could open the unit to check for a fuse or fuses.
if none of the above help,then take the unit to a tech.i suspect a blown channel which means a capacitor needs to be replaced.one more thing...swap speakers over to make sure your speaker isnt blown
Oct 17, 2015 | Marshall Stanmore Bluetooth Speaker
Landrover freelander 04 - one door speaker stopped working a while ago. I've been living quite happily just using the other one. Now the other door speaker has gone too - no noise at all. the only sound is...
You either have blown circuits in the radio itself, or the wire bundle output to the speakers are broken/shorted out or the connector has come loose on the radio/speakers. The last usually doesn't happen however. If the speakers were blown...you would get something. Take your vehicle to a reputable house and have them check it out.
Semper Fi,
Z
Jun 04, 2017 | 2004 Land Rover FreeLander
Need driver for Logitech Z-340 speaker system.
Sounds like the Subwoofer is blown. Unless you are handy with this stuff, you're outta luck unless you can find someone with the expertise to replace the blown speaker inside. This is not an easy job. If you are up for it you can follow the previously described method for opening it & removing the blown speaker. A suitable replacement can be found at http://www.rpelectronics.com/d03-0004-4-speaker-paper-cone-4-ohm.html Note that it will need to be mounted differently than the original which is mounted on the rear of the panel.
The replacement must be mounted on the front. It will need some sort of gasket (foam tape or something) between it & the panel. No soldering is required as push on connectors are used. Connect it up after installation and reassemble the unit.
Be aware that there is a possibility that the sub's amp is blown, in which case replacing the speaker is of no use. It would be good if you had some sort of speaker to connect to the terminals once you get the unit open and check that the amp is putting out before ordering a replacement speaker. Good luck!
Nov 17, 2012 | Logitech Z-340 Computer Speakers
Blown bass speaker, hoping I can buy a replacement.
  1. Contact Altec Lansing.
  2. twist the Speaker frame anticlockwise to open then unscrew the speaker then look for a similar/something close to it(size and amps) one in the local audio shop.
  3. Get it to some audio shop for a recoil and or diaphram change.
May 16, 2010 | Altec Lansing inMotion iM7 (021986950806)...
Archos 605 wifi internal speaker blown
Look on ebay... or find some small speakers from something similar and use those.
Apr 24, 2010 | Archos 605 WiFi Digital Media Player
App comes on and still no sound. Tried a different input device and same thing. Fuses all check ok.
replace onboard amp or try unpluggin speakers and hook them up to something maybe speakers are blown.
Apr 04, 2010 | Infinity BassLink T Car Subwoofer
My speakers are all crackily sounding. when i do anything that requires sound, its very distorted
Hi there bud .1st : make sure you Green Input cable from your speakers are properly plugged in at the back...It must not be touching steel either e.g you Case..
2nd Try it on a different PC , if it does the same , there is something faulty with your speakers , maybe a blown fuse or something.
3rd : if you have got your warranty still on the Speakers, Take it in , and have them replace or fix it..
Hope you come right bud :)
Happy new year
Jan 06, 2010 | Audio Players & Recorders
No Power to Sub
If you think the fuse is blown replace it take card you use the right one (fuse) then see if it goes.
Aug 31, 2007 | Level 9 Sound Designs MM-1000 Computer...
Vizio E470VA 47 1080p 120Hz LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
