Question about Sony PlayStation Portable (PSP) Console
My analog stick came out
My whole analog stick came out when i was trying to pull out knob part
Just pop it rite bak in the hole
Posted on Oct 14, 2007
    Problem Solver:
  • 30 Answers
No you dont need a new psp have you still got the warrenti cus you can take it back to were you got it and dont worri pspz come with a year warranti
Sorry man u got to get a new psp
Posted on Oct 13, 2007
SOURCE:
How do I remove peugeot 306 gear knob
If it's the original knob then you have to remove the gaiter housing (the leather thing around the stick for novices) as the knob extends to under the gaiter and no amount of pulling will remove it without doing this first. It's easy to remove just by lifting from the long edges first and it slips out. The gaiter is secured into the middle of the bottom of the knob by a zippy tie that you have to cut. You can then just pull the whole knob up with a little bit of force but it slips up revealing a white plastic shaft
Jan 24, 2017 | Peugeot 306 Cars & Trucks
Problem with logitech dual pad right analog
Try to disassemble the pad. Reseat the analog stick and re-assemble the pad.
May 12, 2012 | Logitech Dual Action for Pc (963292-0403:)...
We just recently purchased the wireless Logitech PS2 controller...my son has games which you can zoom in and out...but the controller is stuck ZOomed in and will not return to normal w/o having to pull one...
You need to recalibrate the the analog sticks. To do this you need to take out one of the two batteries then press and hold L1 and L2 at the same time. While holding L1 and L2 insert the battery you took out earlier. Now you can release the L1 & L2 and your analog sticks should be centered. Do not touch or move the analog sticks during this process. If this fails to recalibrate then repeat the procedure again.
Mar 19, 2010 | Logitech Cordless Action Controller for...
2004 Lincoln Navigator: gear shifter knob not working
well you go to the dealer and buy a new shifter tie and install it once then never pull the know off again
Jan 03, 2010 | 2004 Lincoln Navigator
I have a ford escort 1993 and i need to rmovwe
turn the knob of the gear stick against clockwise until it is loose, pull the lid with the leather (holded by clamps) and loose 4 number 10 nuts below to undo the whole thing.
Nov 08, 2009 | 1993 Ford Escort 4 Door
Issue with right analog stick - Xbox 360 Controller
I'm afraid I've had the same problem and I can shed a little light on it.
I've tried to fix this but to no avail. I have even transplanted the whole analog stick unit with one from a working controller to see if it will work but I have the same problem.
So, my conclusion the problem is not with the stick itself, but with the microcontroller inside the pad which takes the info from the stick.
I took the analog unit out, and plugged the pad into the computer without it , but STILL the vertical axis on the right stick was pushing up even though there was no input from a stick. It seems to be a fault with the pad, not the analog stick.
Aug 21, 2009 | Microsoft Xbox 360 Wireless Controller
Time does not match
Press the lower left knob till it shows 'H.S.' and then release. Then press the upper left knob once and release. Then press the lower right knob continuously. The analog setting starts.
Jul 02, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
The analog works fine in the options menu but when
Try calibrating your PSPs analog stick, here's how: 1. Go to Settings>System Settings 2. With the System Information screen displayed, rotate your analog stick in a circular motion (clockwise and counter clockwise). This will adjust the analog stick's range of motion. 3. Exit the Settings then run your game and test the analog stick. (it should be working well by now)
I hope this helps.
Apr 12, 2009 | Activision Video Game Consoles & Games
How do I kick off in ncaa football 07 for xbox
You use the left analog stick to position the kick. When you are ready, pull back on the right analog stick and when the gauge fills up, press forward on the right analog stick. The key to a good kick is to position the right analog stick in the same direction of the kick. (As if you were kicking in the direction your turned with the left analog stick.)
Good luck and happy gaming!
Mar 22, 2009 | EA Sports NCAA Football 07 for Xbox
Gear shifter will not go into park
There is a plastic actuator stick under the shift knob. Remove the "horse shoe" clip from the shift knob and remove knob by pulling strait up. You can twist it right and left a very small amount to loosen the knob, but not much.
Once you have the shift knob removed you will see the plastic actuator stick. Push down on the stick and put shift lever in park. If that works, the shift knob or stick is worn out.
Let me know.
Regard,
Feb 12, 2009 | 2004 Pontiac Grand Am
Sony PlayStation Portable (PSP) Console Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
