Lands Phones Logo
Posted on May 08, 2009
What is the mmc for a hot line on a prostar 816
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
73
Points
9helpful
My Prostar 816 will not ring. The lines will light up and flash when there is an incoming call, but I have no ringing sound. How do I get my telephone to "ring"? Thank you!
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
5helpful
I have a prostar samsung 816 plus and we have a number of phones in the office and only one is ringing, how can I make them all ring?
5helpful
Some 816 phones won't ring on incoming calls
6helpful
How do I program prostar 816 to ring?
with the handset down enter #20 the screen should say MMC DISABLED
3helpful
Secondary phones will not ring
with the handset2.gif down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring2.gif assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished. hope that helps
3helpful
How do I turn off ringer for fax line on prostar 816?
2) enter in #62 the screen should say day ring assn
3) press the line button for the fax line
4) press the button for the extensions that you wish to ring (the ones in the right next to the handset)
1helpful
Prostar 816 need to turn ringer on
hope that helps
Ringer
Prostar 816 Toll Restriction
The Station Toll Class of the phone needs to be changed to a Toll Class 5 which allows 911 calls and certain numbers set in MMC # 94. The program to do this is MMC # 30. The problem is when MMC # 30 is accessed it displays the Toll Class for all 16 phones so use caution that you do not change the wrong extension. If you still need help with this problem please repost and I can walk you thru the process.
How do we program to just pick up handset to answer a call without selecting a line?
I had this problem and fixed it by entering programming and then  dayring assignment which is mmc 61. then select the c.o. line (example line 1) then select the phone extensions that you want to ring. this should do it.
Top Samsung Lands Phones Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
