Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Frigidaire stuck in DR mode
I have a frigidaire gas range/oven that seems to be stuck in DR (Door locked mode) although the oven can open and close freely. The memory on the oven seems to think the oven is locked when it really isn't. I've tried unplugging it for a few hours and powering it back on, but the DR still remains and I'me unable to bake. The burners still work fine though. What am I doing wrong here?
  • Official Brand Answer
  • 4,342 Answers
Good Morning ShawnR, thank you for your post!
An error code DR commonly refers to a door lock malfunction. I understand you have reprogrammed the range by unplugging it. It is important to wait approximately ten minutes and then turn your range back on. Typically, this will clear most false error codes. If the error code continues to display, your range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Posted on Dec 02, 2013
  • 1314 Answers
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Posted on Jun 05, 2008
SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Posted on Dec 03, 2008
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Posted on Aug 07, 2010
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
    Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
    Posted on Nov 13, 2012
    The oven door lock is stuck. I can't close the door. How do I release the lock? model #FEF369CGSa
    Hey Susan, thank you for your inquiry!
    Based off the information you have provided the oven door on your Frigidaire range is locked and will not close. You can press and hold the cancel button down for at least 15 seconds. If that does not work, you can perform a reset on your range by disconnecting the power from it for at least ten minutes. If you continue to experience issues with the range please comment back. I would be happy to assist you further. -Matt
    Dec 26, 2015 | Frigidaire 30" Self-Cleaning Freestanding...
    Door lock is stuck closed cannot shut door?
    Good Morning Richard, thank you for your inquiry!
    Based off the information you have provided your Frigidaire oven door is stuck closed and you are unable to shut the door. You can disconnect power from your range for at least ten minutes and that will reset your oven. This may trick your door latch into opening.
    You can also hold down the cancel or clear button for 10 to 15 seconds that may allow your door latch to release. Also attempt to hold down the light and cancel buttons. I hope this information has been helpful to some degree. -Matt
    Mar 23, 2015 | Frigidaire Ovens
    How do I unlock stuck lock?
    Thank you for your post, friend!
    I see that you are having some challenges with your Frigidaire range. On your control panel if you have a "Clear" or "Cancel" button you can hold that down for five to ten seconds and it should release the latch. You can also hold down the light switch button on the oven door frame and the cancel button simultaneously for five to ten seconds to see if that would correct the problem. Last, I would perform a reset on your range which can be done by disconnecting power from the range for ten minutes. I hope this has been helpful. -Matt
    Oct 18, 2014 | Frigidaire Ovens
    Oven is stuck in lock mode
    Hi Lora, this is AP!
    Based on the description of the Frigidaire electric range provided it appears the door lock feature has been activated. In order to cancel the Oven Lockout feature, press clear off and hold for 3 seconds. The control will unlock the oven door and resume normal operation.
    This door lock feature is activated by pressing clear off and holding for 3 seconds. "Loc" will appear in the display, the "Door Locked" indicator light will flash and the motor driven door lock will begin to close automatically. Allow about 15 seconds for the oven door to lock. Once the oven door is locked, the current time of day will appear in the display. If any control pad is pressed with the oven lockout feature active, "Loc" will appear in the display until the control pad is released.
    This information is also located in the owner's manual should you like to view it again, you may retrieve a manual using your model# and the following link http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/.
    I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
    Mar 17, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
    I cleaned my frigidaire oven with the self cleaning and now the door lock is stuck and door wont shut and when you try to turn the oven on the display says dr
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Sep 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Opened oven door before it could lock while I was
    try unplugging the unit,
    depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
    just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
    position
    Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Door locked after cancelling self clean option
    Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
    If you need more assistance let me know.
    Mar 29, 2009 | Ovens
    Frigidaire Gas self cleaning - lock won't release/door locked
    Hold the lock button for 3-5 seconds or Find the main circuit breaker for your oven. Turn it off for fifteen minutes, then flip it back on. This should allow the door to open. Another thing sometimes, the dial for self clean will hang up, but this should fix it.goodluck hope this helps
    pls appreciate by rating as fixyaa. thanks
    Dec 23, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    635 people viewed this question
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    ashburton
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
