Managemylife com have 110v to circuit board but no where else, if you leave it unplug for 24 hrs it might work some times ROBERT WADE
    Genius:
  • 1,198 Answers
I would check the price on a new circuit board, probably cheaper than a service call. Available at Repairclinic.com probably.l
Posted on Nov 27, 2013
LEFT DOOR OPEN OF FREEZER. CLOSE3D DOOR FOR 24 HRS. nOW LIGHTS FLASHING ON SUPER COOL AND SUPER FREEZE.
You will need to unplug and defrost the fridge for a few hours then replug the power. Leaving the doors open allows moisture to freeze on the evaporator while compressor continues to run confusing the control board
APPLIANCE911
Apr 10, 2016 | Hotpoint Combi FFFL1810G Graphite 297 l...
Samsung flatscreen tv model LN46C600F3FXZX has sound but no picture
Video section has become compromised and no longer functional. Audio being separate from the Video may work perfectly, but the Video portion sustained damage to the circuit board or the inline safety diode blew. If any parts of the Circuit Board fail, you need to replace the mainboard. The cost to generally fix a circuit board is usually more than the replacement cost for a new unit. Check all fuses or circuit limiters inside the TV and if there are no shorts, burned parts, or obvious smells on the mainboard, transient current may have trickled in and damaged sensitive electronics. Have a professional Technician do tests to locate the source of the problem.
Dec 25, 2013 | Samsung Televison & Video
Kenmore dryer
-There are feel things that cause a dryer not work:
-Thermal fuse, heater element, door switch, start switch an motor.
Good luck
Mai
Dec 11, 2013 | managemylife.com
Freezer works refrigerator does not
Check the thermistor. You can unplug the thermistor from the circuit board located on the back of the refrigerator. It will be the clip in plug located at the left of the board that has two wires in it. Leave it unplugged for 24 hours. If the refrigerator cools down, you have a bad thermistor.
Aug 30, 2013 | Dometic RM2652 Refrigerator
Freezer not working
did you unplug it it could be that the freezeer tubing is fozen need to unplug it off and if you dont open the door leave it off so it can defrost for 12-24 hrs then plug it in just dont open the door so your food could be safe after that i had the same proble again unplug leave off for 12 to 24 hour best at noght before you go to bed then replug it will take a few owers to get cold again but that schould work
Oct 09, 2012 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Sony KV-32HV600 will not turn on. Light blinks then nothing, have left it unplugged for 24 hrs, worked a couple of times but now nothing. Have disconnected it from cable, still nothing. Looked online...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 22, 2017 | Sony FD Trinitron KV-32HV600 32" TV
Our DVR won't start up
usually this occurs when dust or moisture is on the circuit boards.
Put the dvd in a warm room , plug it in and leave for 3 hrs.Then unplug ,replug try to start.
Just try it.
Nov 20, 2009 | Cyberhome DVR 1600 DVD Recorder
Only the red light comes on
Whats up Wade?
This is DVD MIKE with Perfectimagess.Try this first .Unplug the TV for a while and press the On/Off button which is supposed to perform a "reset".After that, plug the TV back in. It should come on and the Timer light off. The picture and colors might be distorted, but pressing the Perfect Focus button on the remote control resolves this right away.
The problems is a black picture or the TV won't turn on. The Timer light stays lit even though no Timer has ever been set. The colors converge and the picture is pinched. I don't think all of the expensive repairs are necessary, My TV did go out after a week of non-use while out of town (I was out of town, not the TV). I don't know. I'll post more if I learn more. I hope this helps Wade,
Vacuum the dust off of the circuit boards and inside the cavity. TAKE CLOSE UP PICTURES OF THE CONNECTORS BEFORE DISCONNECTING FROM THE CIRCUIT BOARDS. (IF YOU HAVE TO.) TAKE OUT CIRCUIT BOARD MOUNTING SCREWS. AND REMOVE THE BOARDS.
VACUUM THE DUST. LOOK- SMELL AND CLEAN THE GROUNDS, AND CAREFULLY CLEAN THE BOARDS. ASSEMBLE. DOUBLE CHECK CONNECTIONS WITH PHOTOS,
AND PLUG IN, TURN ON AND HOPEFULLY ITS ALL GOOD.
WADE WORK WITH ONE HAND AS MUCH AS POSSIBLE SON!!
DVD MIKE
May 14, 2009 | Akai PT4298HD Rear Projection Television
Refrigerator doesn't stay on.
sounds like when you moved it you created an air lock, when moving fridges etc. should always leave for 24 hrs to settle before plugging in.... , no guarantee but try laying it down and leaving overnight then stand it up again and leave for at least 24 hrs for the refrigerant to try and sort itself out. UNPLUGGED from mains of course... good luck
May 02, 2017 | LG LFX25960ST Stainless Steel French Door...
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
