Question about Makita BDF452HW 18V Cordless Lxt Lithium Ion 12" Driver Drill Kit
Makita BHP452ZW light works but no drill power
Batteries are defiantly working ok and brushes are also fine.
  • Makita Master
  • 885 Answers
Your most likely problem is the switch (PN 650583-6). When they go bad they will let power go to the LED light but it won't get to the motor. With a multi-meter, check the power going into the switch and coming out to the motor. If 18 volts are getting through to the motor then you may have armature (PN 619198-8) issues.
Posted on Apr 01, 2014
dmftrucker
  • 1922 Answers
SOURCE: My makita drill is weak/ has no power.
did you check the battery under a load condition?as in check the voltage under drill operation,most batteries will check their normal top charge voltage when not being used,this is known as a surface charge,but under load the voltage may severly drop leading to burned or overheated armatures,have it load tested
Posted on Jan 02, 2010
rowdy45176
  • 2176 Answers
SOURCE: Can't get the keyless chuck off cordless Makita 6095D drill.
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
Posted on Dec 31, 2008
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Posted on May 23, 2008
SOURCE: Makita drill 6349D
dont think its http://www.toolbarn.com/product/makita/6349DWDE/
Posted on Oct 05, 2008
  • 165 Answers
SOURCE: Brand new Makita DC18RA charger wont charge the batteries.
Return to store for replacement.
Posted on Feb 27, 2010
Model 7000 slide not working
I have a Defiant 7000 flashlight and took a look. When the light is closed, the top of the battery door (1) is right at the lip (2) that keeps the light from over extending. I couldn't get mine to close with the cover loose, but if you did you could carefully drill a hole (3) in the outer casing to see and push the battery door back into place. You could also remove the two philips screws under the rotating magnets on the base and maybe push hard enough to force the top out?
Feb 22, 2014 | Defiant Camping, Backpacking & Hiking
Defiant headlamp; where's the tab to be removed?
If you are talking about a shipping tab that prevents the batteries from discharging during shipping, look inside the battery compartment.
There should be a plastic, or cardboard tab, that prevents one of the battery ends from make contact with the flashlight. Just pull the tab to remove it.
Mar 24, 2013 | Defiant Headlamps, Lanterns & Spotlights:...
Drill just stopped working it was working fine on saturday went to use it on sunday and it was dead
Could be the battery(s) went dead, possible but usually two batteries won't go at the same time. If you're sure the batteries are OK, check the 'headlight' when you squeeze the trigger. If it isn't coming on it's the battery or the switch may have burned out. Next, check the brushes. They're under the two caps at the back of the case. The carbon should be about 3/8 to 1/4 inch long and the springs should be in one piece and strong enough to push the brushes down on the armature. Next, put a drive bit in the chuck and check that the armature turns freely. There will be some resistance because the transmission is geared from the motor to the chuck but it should turn smoothly.
Aug 16, 2010 | Makita 12V Cordless Impact Driver -...
Put in new batteris and nothing happens. They are
First, make sure that the "new" batteries have a full charge. If you don't have a meter to check them with, try using them to power something else. Also, if using rechargeable batteries, make sure that they are the correct type for the camera. NiCd batteries will not work well in a camera that calls for Ni-MH batteries.
If the batteries are OK, your problem may be due to corrosion on the battery connections inside the camera. Remove the batteries and wipe the camera contacts with a clean soft cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any specks that may have fallen into the battery compartment during cleaning, then clean and reinstall the batteries.
The above clears about 90% of power-up problems, and I hope it works for you. If not, your camera may have a more serious problem that requires repair by a camera shop or the manufacturer.
Aug 20, 2009 | Kodak EasyShare C663 Digital Camera
Kodak DX3900 camera can't get power from battery
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Mar 13, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
Makita BDF452HW 18V Cordless Lxt Lithium Ion 12" Driver Drill Kit Logo
136 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
