Question about LG DLE2050 Dryer
Dryer not heating - LG DLE2050 Dryer
  • Stephen Rountree
    Stephen Rountree Nov 27, 2013
    Sincerely appreciate your responses, I will pursue those items.
  • 2,113 Answers
Did you try turning off the double 30 amp breaker in the breaker panel and resetting it?
Posted on Nov 26, 2013
  • Stephen Rountree
    Stephen Rountree Nov 26, 2013
    Turned off the breakers and tested for the electric for 220...
  • mikadot
    mikadot Nov 26, 2013
    Then it is either the heating element that has gone bad or a thermal cutoff
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
DRYER WON'T HEAT
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
www.partselect.com/Repair/Dryer/Not-Enough-Heat/
When your gas or electric dryer is not producing any heat or not enough heat to ... If the sensor is defective, either the igniter won't glow or the gas valve won't ...‎How to test a dryer's heating ... - ‎How to open your dryer's cabinet
How To Troubleshoot A Dryer That Won't Heat ' PartSelect ...
? 4:23
www.youtube.com/watch?v=ahb5pt52drE
Oct 6, 2011 - Uploaded by PartSelect
How To Troubleshoot A Dryer That Won't Heat ' PartSelect.com ... If you're using an electric dryer check ...
Oct 30, 2015 | Dryers
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    Kenmore dryer not heating up
    If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
    if you dryer is gas check out this gas no heat tip....
    If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
    check out this electric no heat tip...
    heatman101
    Nov 15, 2010 | Electrolux AEQ8700F Electric Dryer
    Dryer will not heat. It would initially heat but then the heat would stop.
    Check out this tip that will give more details…
    Gas dryer not working gas dryer not heating
    http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
    Check out this tip to see the things that can fail to cause your electric dryer not to work.
    Dryer Troubleshooting Electric dryer wont heat
    http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
    heatman101
    Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
    Dryer won't heat up. It starts to heat then goes off
    heatman101
    May 21, 2010 | Kenmore 63942 Dryer
    LER4634J Electric Dryer: dryer will not heat...
    heatman101
    [p]
    May 17, 2010 | Whirlpool LER4634J Electric Dryer
    My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
    dryer_heating-element.jpg Heating Element
    dryer_thermal-fuse.jpg Thermal Fuse
    dryer_thermostat.jpg Thermostat
    dryer_timer.jpg Timer motor
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
    Whirlpool dryer will not heat
    Hello there:
    There are 5 things that would not make the dryer heat up i will post you them here ok
    Jan 17, 2010 | Dryers
    The dryer does not give heat
    Hello there:
    Proper Voltage
    Jan 14, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
    LG DLE2050 Dryer Logo
    81 people viewed this question
    Top LG Dryers Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Mike
    Mike
    Are you a LG Dryer Expert? Answer questions, earn points and help others
